CV joint (MKII ABS) input stub - strange one
John Plum
My Cars:
x 5
Contact:
Post by John Plum »
Speaking to Nigel Thompson driveshafts, he reckons that the car may have been originally designated as a HDI, with HDI hubs but then fitted the 1.9TD/AL4 TD. The HDI has the longer CV joint stub, but with a 39 (not 34) inner spline.
If there were a few thousand cars to deal with in this way, they may have made driveshafts and CV joints to suit, matching the HDI hubs. The driveshaft was probably made in the UK by GKN (who only speak to car manufacturers).
The only thing is, no supplier has heard of this before, as if I am the only one.
He suggested I use the new (shorter stub) CV joint with the original flatter nut I have, torque it up, with loctite (Which Audi do on their cars). WHat do you reckon, safe eh?
John Plum
Xantia II Estate,1999, 2.0 HDI LX, 17000 miles, manual
John Plum
My Cars:
x 5
Contact:
Post by John Plum »
Well that's what I did, with loctite and some good torquing down, as per Audi. So no split pin. I see the original driveshaft nut isn't a 'locking thread ' type. Would be nice to have one of those for the shaft. I want one ideally.
John Plum
My Cars: Currently:
In the past: 3, CX td Safaris and about 7, XM td estates. Lovely cars.
x 1205
Post by Peter.N. »
That should do it OK
John Plum
My Cars:
x 5
Contact:
Post by John Plum »
Hi Peter: I thinks so.
Thread locking nut would be ideal (if anyone knows whre to get these for our axles, I'd be interested).
John Plum
addo
Sara Watson's Stalker
Location: NEW South Wales, Australia. I'll show you "Far, far away" ;-)
My Cars: Peugeot 605
Citroën Berlingo
Alfa 147
x 93
Post by addo »
Member "Geoff Lebowski" had some driveshafts for sale that might also have the correct stubs. I just remembered.
Kowalski
My Cars: Ex 05 C5 2.0 HDI Exclusive 145k
Ex 97 Xantia 1.9TD SX 144k
Ex 94 Xantia Dimension 1.9TD 199k
Post by Kowalski »
What part numbers did service.citroen.com list for you car?
If you put the VIN number in there, it should list the parts your car was built with.
addo
Citroën Berlingo
Alfa 147
x 93
Post by addo »
I was thinking this through earlier.
Series II cars have only two different hubs, depending on the "duty" level anticipated of the hub. It's where the track width variations occur.
They also have two possible types of joint, per inner and outer location. Gruntier motors used driveshafts with the larger joints.
Based on that, you'd think there would be three outer stubs. Basic everyday for the narrow hub (small joint), basic for the wider hub (small joint), and heavy duty for the wider hub (large joint).
John Plum
My Cars:
x 5
Contact:
Post by John Plum »
@Kowalski: Hi there.
Driveshaft offside (right side) part No. as 3273 9W
John Plum
Post Reply
