Not sure about an additional water temp. gauge but my S1 V6 Exclusive had the oil temp gauge!!andmcit wrote:Forgot to say, giveaway is the additional water temperature gauge!! Only s1 Activa and VSX have this...
Andrew
Do Xantia Athena models have hydractive??
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
2001 Xantia 3.0 Exclusive
1999 Xantia 1.9TD
1997 Xantia 3.0 Exclusive
1995 XM 3.0 Exclusive Estate
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
- Dommo
- My Cars: Current
07 C5 VTX+ 2.2 HDi 173hp
97 S1 Activa
06 Boxster S
93 XM 2.1 Turbo SD
Previous cars
91 Toyota Soarer UZZ32 Active Suspension
97 S1 VSX 1.9 Turbo D
99 Xantia Activa
98 2.1TD Xantia
99 306 - x 19
I'm afraid that might be the caseandmcit wrote:Forgot to say, giveaway is the additional water temperature gauge!! Only s1 Activa and VSX have this...
So the Activa's days are numbered!?
Andrew
I wish I could fit a 2.1TD engine to it, I just can't afford to run two cars, and don't want to put 70 miles a day on the Activa, although I know it could do it perfectly well and reliably. I would rather put the miles on a cheaper to run diesel like the 1.9 VSX.
Interested Andrew?
Yes they did indeed... Instead of a relatively usefull oil temp. gauge I now have a 'gauge' telling me which gear I have selected (in an auto) doh!!!andmcit wrote: Yep, the Exclusives are reworked VSX's so yes the same(ish) but Citroen played around with the s2 dash a bit more in this area...
Andrew
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
Oil pressure gauge was more the norm in my early motoring day's and I had a Mazda RX7 with the rotary engine for a number of years... it had a loud buzzer at 10,000 rpm, it was the only way to know you were over revving... talk about smooth as a sewing machine!
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
Well Dommo, if you're down in Ascot may as well take a "small detour"
for a replacement s1 colourcoded front bumper in white:
http://cgi.ebay.co.uk/Citroen-Xantia-N- ... 0429936180
Make it a bit of a roadtrip then!
Andrew
Andrew
