your confidence is almost contagious Jim but then your not aware of the new pistons i made from old bean cans, Aldi beans too!
MK1 XM headlamps for those whom may be even slightly interested are pictured above, they are clear lenses with a plastic freznel, sort of. The outer lamp that is the indicator on a Xantia is the XM's side lights.
Morette headlamps are actually what looks like an ABS body and seperate cover which you paint to match not a steel frame as i thought, funny what the passing of time does to the grey matter! instead of one side light, a dipped beam and a high beam as fitted standard the Morette setup gives one dipped beam projector and two main beam units per side with a sidelight bulb built into each main beam unit
D
