Dean's Activa/XM/V6 and now Talbot blog
- x 1521
- x 87
Re: Dean's Activa/XM blog
Were these nice XM and Cx's known reliable and solid cars or were they glossy near purchases of a potential money pit? it could of been the later but i guess you will never knowHell Razor5543 wrote:But you ended up with Otterchops, so all is well that ended well.Xantianut wrote:Walking away from a nice XM is one of,my real auto regrets, just as walking away from a nice CX......
And what on earth is "otterchops" (im hoping its not an affectionate name for the wife).
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
- x 87
Dim moment, the car is called Otterchops, very individual.
In true chav style all my cars are called Betsey!
D
D
XM Prestige PRV6 92
- x 111
Ay up!!!
I suspect they were moneypits. I have my father's back of buying a junkheap!
Otterchops excepted of course.....
C5 HDi 110 SX (Fifi 7 or Otterchops)
RIP
Citroen Xantia 1.8i LX (Fifi 6)
BX16TRS (x2) (Fifi 4 and 5)
BX19DTR (Fifi 2)
BX14E (x2) (Fifi 1 and 3)
RIP
BX19DTR (Fifi 2)
- x 87
I think some of my insides are now poking out but i got the engine and box into the shed this evening after bringing it back last night, it want until 10pm i realised it wouldnt fit throughh the door of the shed with the headers on which was interesting but its done now.
Need to close that shed door and concentrate on finishing the bathroom now!!
photo(39) by Deanxm, on Flickr
photo(38) by Deanxm, on Flickr
photo(37) by Deanxm, on Flickr
D
D
XM Prestige PRV6 92
- x 6831
What's going on with that engine then Dean? Do you have a V6 XM now then or are you doing a conversion on yours?
I've clearly missed an important bit somewhere!
- x 87
There is a slight conversion on the cards, i think someone shouted "change places" and now a few engines are going to jump from one car to another over the next year
D
XM Prestige PRV6 92
- x 6831
Excellent Dean I shall be watching progress with great interest!
- x 87
ER or casualty or some rubbish was on tonight so i had to "go and clean up the mess from todays work down the garden"..................
Oil in the V from an unknown source, may be nothing
photo(41) by Deanxm, on Flickr
I performed a hand cranked compression test with all other plugs out (bloody hard going) most of the inlet valves arent seating well at all but look clean, higher compression cylinders have a tan colour to plugs, lower comp cylinders have black rich looking plug tips, one plug has rusted away.
photo(40) by Deanxm, on Flickr
Front bank return water way was (until i broke it out) completely closed off with a hard crust, there were some nuts stashed in the water pump outlet, gearbox bell housing and exposed spark plug recesses.
photo(42) by Deanxm, on Flickr
I need to get the crank pulley off to release the timing chain cover, the chain and guide blocks look very good which would confirm low miles, chains look very good too so will probably just clean and re-use, once the timing cover is off i can get the heads out of the way and check each of the bores to make sure there is no corrosion and the rings are free, if its all good i can start stripping the heads down and get them off to Fred for any required machining work.
Sad facts for the night, the 4HP18 autobox uses the same final drive and gear ratios for all injection, turbo and V6 engines, only changes were made the the bell housing adapter plate and valve body, all auto boxes use the same drive shafts aswell which i kind of knew but its nice to confirm it, that will make life easier.
The exhaust flange from the headers is also the same size as my injection engine, the injection 8v reduces pipe size after the cat where i guess the V6 does not so i should be able to fettle the new cat i got to fit if the one on YOG is a bit too tired.
Looking good so far.
D
D
XM Prestige PRV6 92
- x 6831
I used to do the same... Could never stand those shows whereas all the rest of the family love them; Robyn especially... Should have known then she'd grow up to be a nurse!!!Deanxm wrote:ER or casualty or some rubbish was on tonight so i had to "go and clean up the mess from todays work down the garden"..................
Better to work on a V6 any time than rot in front of a TV Dean
It certainly is Enjoying this immensely!Deanxm wrote:Looking good so far.
- x 87
Me too Jim, once it is stripped down I can see what's needed and start sourcing parts to re-build.
So far I'm going to need;
Heads skimmed
Head bolt set
Pair of head gaskets
Set of valve stem seals
Cam seals
Crank seals
Torque converter input seal
Driveshaft seal
Inlet manifold seals
Starter motor
Heat shields for above
ENGINE COVER
Icv
Full gasket and stud set for exhaust
Stat
Water pump?
Rotor, dist cap and red plug leads
Distributer cover
Belt set
D
Heads skimmed
Head bolt set
Cam seals
Crank seals
Driveshaft seal
Starter motor
ENGINE COVER
Icv
Stat
Water pump?
Distributer cover
Belt set
D
XM Prestige PRV6 92
- x 6831
You have all winter to sort that lot out Dean and I'm sure Matthew can be of massive assistance in securing all you need
Think of all the episodes of Casualty you now have the perfect reason not to watch!
- x 87
Ive not been in the shed again this evening.
Follower and ballancer assembly, followers are all alloy
photo(48) by Deanxm, on Flickr
First look inside, this head was taken off first as its cylinders had the lowest compression (4.1-4.8-8.1bar respectively) and it looks good, im certain all the compression loss was due entirely to bad valve seats.
photo(50) by Deanxm, on Flickr
bad detritus buildup in the water jacket, the heds had to come off.
photo(47) by Deanxm, on Flickr
A quick wipe with a dry cloth on the piston crowns
photo(49) by Deanxm, on Flickr
The outcome so far from tonight, the crank pulley is toast, its cracked along the keyway slot right were the crank seal runs, oil pump is excellent, bores are excellent, no wear lip, no heav rust and hone marks still clearly there, piston rings are floating nicely and the water jacket is full of potentially catostophic crud.
Worth lifting the heads off.
D
D
XM Prestige PRV6 92
- x 87
Taste of things to come
photo(55) by Deanxm, on Flickr
Exhaust Port (Rough as a badgers)
photo(58) by Deanxm, on Flickr
Inlet Port (Nice)
photo(62) by Deanxm, on Flickr
photo(63) by Deanxm, on Flickr
Cylinder head
photo(56) by Deanxm, on Flickr
Things are moving on nicely now, will stall for a week now while i finish the last bits of the bathroom and spend some time with the little one but then back to it
D
Inlet Port (Nice)
Cylinder head
D
XM Prestige PRV6 92
- x 6831
Looking like new Dean
