finding a live connection only on with ignition???
MikeT
My Cars: 2005 C5restyle 1.6HDI 16v 110hp VTR Estate
2008 C5 X7 1.6HDI VTR+ Saloon
x 232
Post by MikeT »
A relay is just an electrically activated switch in simple terms. You apply a voltage (12 or 24vDC for automotive applications) to two terminals (the coil) and it will "relay" whatever is connected to the input terminal out through the output terminal.
In your case, you'll apply the 12v from the oil pressure switch to turn it on and it'll relay whatever high current feed you rig up on to your fuel pump.
Post Reply
