I had to do it by hand.
And it was quite unpleasant
The tool will (should) fit yours as there is space to do it properly.
Method I used:
Disclaimer: Fingers / engines / springs do not mix, caution
Having mounting off, insert spring and plunger. Bear in mind my plunger was seized again so I 'had' to take it off.
Set tensioner roller about midway (only so its 'level')
Holding plunger in with a finger, attempt to put in place (get the plunger to touch the arm so it cannot fall off) , ignore alignment at this stage just gently sit plunger onto tensioner 'arm' where it should live.
At this stage, very carefully hold the mounting and attempt to fit the tiny top bolt (the one going from the engine side outwards) , just fit it about 3 turns.
Insert piece of wood between inner wing and mounting lower. This is because if the mounting moves 'out' (towards the wing) the plunger will fall out)
While its like that, forcefully twist mounting to align another bolt hole and insert bolt finger tight.
Once it has two diagnostically opposite bolts fitted it cannot move or fall off.
It's not as bad as it sounds, but expect some cursing and allow about half a dozen attempts.
That's the method I used anyway due to lack of space, you could in theory push it from underneath but I find that difficult.
If you can get the tool use it.
Note: The tool replaces the lower two bolt holes, on some cars (Visa (are there any left?) springs to mind if I remember correctly) you cannot use this tool as the lower bolts will NOT come all the way out (they undo and come out with the mount itself)
Andy.
