Clutch cable snapped.
Black plunger assembly is just prised out, towards front of car, after lifting pedal as far as it will go.
I found this out from a search about clutch cables/clips, and having to do the same cable clip job as you, Dave. Never having removed it before, I approached it very gingerly, prising it out using a screwdriver - after it's moved a couple of mm, it becomes free
Martin
1995 Xantia TDLX (deceased )
