it's just the awkwardness of getting to the pipe that worries me, some things are a bit tricky for me to do
have a look on youtube.com/amazingfeet that should explain why!
I didn't realise they had a gsf in pompey near st marys, i bet you can't park there though!!! you never can in the one in worthing or cosham they always seem to open shops and forget about the parking!!!
better get the a/s done too then or flog the car!!!
I can't afford to get garage to do it though as i want id done properly!!!
cheers
Richie
Speedo and cruise control, airbag light and alarm probs
- Xaccers
- x 184
Of the latest C5, only the top of the range has LDS hydraulics.xantia sx auto wrote:I thought citroens still did hydraulics as i saw one on topgear, don't tell me they've gone back to leaf springs!!!!!???
DIY sphere tool
DIY sphere tool
- Xaccers
- x 184
Accumulators are the same across all Xantias
DIY sphere tool
DIY sphere tool
bleed screw
does anyone have a piccy of where the bleed screw is to de presurise the suspension system, do i need to bleed the air out after changing the accumulator or does the car do this for me???
thanks
thanks
- Sara Watson's Stalker
- Location: NEW South Wales, Australia. I'll show you "Far, far away" ;-)
- My Cars: Peugeot 605
Citroën Berlingo
Alfa 147 - x 93
Depressurising screw is right near the accumulator, on it's black painted mouning block. Look for a small bolt with a chunky (thicker than normal) head. You'll know if it's the right one, as with the car just turned off, a half turn of the correct screw will see a squawk from rushing fluid (it won't leak out), and the car will rapidly settle.
Don't confuse it with the two bolts which fix the accumulator assembly to the engine block - the half turn and listen trick will sort this out.
- Xaccers
- x 184
The bolt head looks a bit like a chef's hat.
DIY sphere tool
DIY sphere tool
