Brand New Xantia - Straight off the Production line!!!
Engine
Model xu10-j4R
Type 2.0i 16V
Valve quantity 16
Cylinder quantity 4
Bore & storke 86.0 * 86.0 mm
Displacement 1989 cc
Compression ratio 10.4 : 1
Fuel supply system Injection(4 dots)
Fuel pump type Electric
Fuel type Lead-free
Fuel consumption in out city per 120 7.7 Lit/100 km
Fuel lid side Right side
Max .power 62.5/5500 hp/rpm
Max. torque 103.3/2800 Nm/rpm
How do they get 62.5 hp from a twincam 2 liter engine? Is it powered by kermit spunk or something?
Model xu10-j4R
Type 2.0i 16V
Valve quantity 16
Cylinder quantity 4
Fuel type Lead-free
addo wrote:I would assume it's been converted to steel sprung suspension.
Wonder if they'll do a RWD version, as for the 405?
I have emailed them with a question about the suspension, and I am looking forward to their reply.Xac wrote:Well it may be a source of cheap new strips
I wonder if it has been converted to springs though.
ACTIVA
What's that the FS1E untuned version of that engine, with tuning restrictors in the ports!seisporting wrote:Engine
Model xu10-j4R
Type 2.0i 16V
Valve quantity 16
Cylinder quantity 4
Fuel type Lead-free
ACTIVA
Well yes good point!DickieG wrote:In the cutaway drawing you can see the suspension spheres.
Although reading this spec list.......
Air conditioning system
Central locking system
Remote control switch with immobilizer
Front & Rear power windows
Driver's and front passenger air bag
Side impact bars in front & rear doors for passengers safety
Safety seat belts with auto quick puller system
Central arm rest & rear seat folding arm rest for skis
Digital monitoring : out temperature, clock, speedometer, date
Driver adjustable organic seats
Heater rear window & wiper with alternate function
Windscreen wiper with automatic rain sensor & two speeds with manual control
Sun visors with mirror (Driver's Sun visor with folding mirror)
Catalyst convertor with Euro II standard
Front & rear fog lamps
Carter steams filtering system
Front wheels brake ventilated disk with brake pad wear monitor
Access from front cabin to trunk
Power side mirrors system , heated side mirrors
Fuel evaporating control system
Digital AM /FM radio/cassette & CD changer with 6 speaker
Fuel inertia switch in case of accident & upside down
OBD Engine defect finder light
Power steering wheel
They mention clock, speedometer.....Well that's a basic spec most cars have yes even a clock, but the speedo is a legal requirement. So mentioning that in their list is odd!
The seats are organic?
Nice and environmentaly, friendly or is it a typo for orthopedic, but wouldn't it be better if they were orthopedic
Rain senor wipers are not a standard spec on other vehicles.
Whereas sun visors are!
Therefore they seem to be missing out on mentioning two things they could put in the spec sheet.
As it's been sold in a hot climate, then the parcel shelf sunblind should be a important point to mention.
Also the spheres are a special thing, with all the comfort factor that goes with this suspension design, so why not make it an item to draw attention to!
Instead they don't mention it, and have used an old cutaway diagram, so therefore what have they done, or not done to the suspension?
Keeping it original saves on changing a proven system and costs.
I would if in their place leave it as designed, but it would be good to find out what they have done to it!
ACTIVA
Well they will also get nourishment if the driver has flatulence!CitroJim wrote:Yes. You have to mow them on a regular basis...ACTIVE8 wrote: The seats are organic?
There's a built-in scuttle leak to keep them watered....
ACTIVA
Apparently the seats are called Scorpion, so as the driver lets rip, plays their bum note, and eh....gases through the organic material, it plays "Wind Of Change!"addo wrote:That's "carbon sequestration" in modern green-speak.
ACTIVA
- quintet
- Donor 2023
- My Cars: 2.0 hdi Peugeot 307
- x 41
Maybe they've got 'aircraft' seats in them as seats on aeroplanes have carbon built into them so when someone 'lets one off' the rest of the passengers don't cop for it too, or at least that's the theory . By the way if those of you who have access to a lexia you should see pics of the latest ZX's on there too (& possibly Xsara's too), i think they're destined for the chinese market much like those special zx's of many moons ago. as for the Xantia, well its no 'looker' but most new cars aren't these days, if it were to be made available in the UK it'd best not be multiplexed or you wont see me on the waiting list.
Music keeps me going.
Thanks CitroJim!CitroJim wrote:Very goodACTIVE8 wrote:it plays "Wind Of Change!"
Only trouble is, I have that tune stuck in my head now...
I had my "Wind Of Change" at the time of the previous post I.E. 1st April but held it back, and didn't follow through until now, otherwise that tune would have stuck around for longer!
ACTIVA
