my l reg citroen xantia
My Cars: Mazda 6
Ooops.
Previously:
2009 Honda Civic :(
C5, C5, Xantia, BX, GS, Visa.
R4, R11TXE, R14, R30TX
x 4917
Post by myglaren »
They probably did a few random ones to see what they looked like, before implementing it factory wide. I've worked in places that pulled stunts like that :(
kevino
My Cars: i have a c5 vtr which i love.
Ive had, visa GT, 2cv, dyane, BX X 5, 2x xsaras, mark 1&2.
x 3
my l reg xantia
Post by kevino »
I'm glad they did, she looks mighty fine to me :lol: :lol: :lol:
I want to go peacefully in my sleep just like my granddad, not screaming like his passengers
DickieG
Monaco's youngest playboy
My Cars:
x 38
Re: my xantia
Post by DickieG »
kevino wrote:hang on here guys,
there seems to be a bit of a problem here, my xantia has the rp number 6323 and my xantia has the anti sink, power steering and the chevrons on the bonnet not on the grill ???
Xmexclusive wrote "The chevrons change to grill date was from RPO 6295.
Source 1995 model year briefing note" isn't this after my rp number ?
The debate goes on !!!
kevino
Replacement bonnet and grille?
13 Ram 1500 Hemi
14 BMW 535D Tourer
19 BMW i3s
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
citroenxm
My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising
x 71
Post by citroenxm »
Nope Richard, as theres no air bag either, and no pretensioners, and no side impact in the doors...
Shes defeantly a 1994 L reg, chevrons on bonnet original!
I went and checked mine this morning, but shes before the RP number, as said.. by about 9 cars..
Paul
A very sad...
1994 XM 2.1 d auto
Old-Guy
My Cars: 2011 Grand C4 Picasso VTR+ 1.6HDi in Kyanos Blue
1995 Xantia Estate SX 1.9TD in Vert Vega "The Green Lady" - now owned by XanTom
x 17
Post by Old-Guy »
Just a couple of points on specification changes:
Where a manufacturer makes a number of similar models, particularly on different assembly lines, it's inevitable that the 'run-out' of a particular feature will not be simultaneous across all models.
My 1.9TD SX estate is a good example. Built in January 1996, registered 21/2/96, it is in fact to 1995 model year spec.: no engine ECU, sun-roof, no air con. The supplying dealer added various 'goodies' - CD auto-changer, luggage net, towbar with full electrics (the latter had not been used in the cars first 11 years) - perhaps as a sweetener to shift it quickly.
Don't forget too that the registration date (and letter) can be long after the actual build date - it's not unknown for new cars to sit in a field for 2 years, as manufacturers stock, before being registered. While this may never have happened to Xantias, a dealer could have had a new, un-registered, car in the showroom or compound for many months before shifting it, if it's a colour and/or spec that nobody wants.
1995 Xantia Estate SX 1.9TD in Vert Vega "The Green Lady" - after 11 years now owned by XanTom
citroenxm
x 71
Post by citroenxm »
Engine ECU didn't come untill LATE 1996 to 1997, much nearer P plate cars..
Ive still to see an N reg 1996 (early 1996) plate car with an ECU.
Paul
A very sad...
1994 XM 2.1 d auto
xmexclusive
My Cars:
Post by xmexclusive »
Hi All
While looking again through the Citroen Xantia workshop manuals to recheck facts I came across another little gem that is worth recording.
In booklet BRE 0085 GB additive No. 5 dated Nov 1995 there is a note about the 3 types of sphere diaphram stating that the multi-layer (Multicouche - marked with 3 pimples on the end) was added to the range from RPO No. 6056 (June 1993). It also states that pressure test on this type cannot be relied upon as during a test the reading can exceed the nominal value.
The real gem though is the final note: The suspension cylinders on both sides of the one axle should be equipped with the same diaphram type.
Now that is a restriction that I have never seen mentioned before.
Now found booklet BRE 0050 GB dated March 1995. Suspension SC/MAC Citroen system for retaining a constant ground clearance: operating principle.
Since December 1993 all the Xantia vehicles with power assisted steering have been equipped, in production with the SC/MAC (Citroen system of maintenance of a constant ground clearance).
This system is fitted to both Hydractive and non-hydractive vehicles but note that the SC/MAC valves are different for each type of suspension and not interchangable.
The description "Anti-sink" is not used in any part of the document.
Sphere no. 11 is described as SC/MAC sphere.
Its operation description is simply "The SC/MAC sphere returns fluid under pressure to feed the rear brakes".
Now got to BRE 0085 additive No. 3 dated july 1995
That contatains 80 pages on suspension, steering, brakes.
Now gives the correct "anti-sink" reference.
Page 26 - Removing/refitting : The front anti-sinking valve.
Page 27 - Removing/refitting : The rear anti-sinking valve.
John
Xmexclusive
Post Reply
