All Things V6...
DHallworth
Donor 2016
x 63
Re: All Things V6...
Post by DHallworth »
Well, it’s been a fairly easy few months on the car front. The only car we’ve had any problems with has been the C4. The car had a new AdBlue tank fitted to it just before we bought it. In February it needed a new NoX sensor which was done under warranty. Then during lockdown it started flagging a Urea Fault again. I did some looking into the fault codes and it was for a Low Pressure Fault on the AdBlue system.
It turns out the AdBlue pump is built into the tank and means that the whole tank needs to be swapped out, again. Thankfully, it was still under warranty as a new tank inc fitting would have been around a thousand pounds! A grand for a pump and a p**s tank!! :shock:
Anyway, since it was done, it’s been running great. My wife uses it daily, it’s almost 12 months since she got it and I doubt I’ve done 100 miles in it. I took it to get some Diesel for her the other night as she made dinner and realise just now nice a car it is. The suspension is really nicely damped providing a nice smooth ride, the seats are comfy and the road noise in the car isn’t bad either. It’s actually a really nice little car to spend time in.
The tyres are all down to around 3mm and one has a nail in it. Cheryl has just started working in a village called Kilmalcolm which is all back roads from us. In the winter, these roads can be untreated as well so today I’ve ordered a set of Michelin Cross Climate + tyres for it. Including delivery they were £240 which isn’t bad at all.
This weekend I’ve spent hours giving everything a clean. All of my Citroen C cars are spotless for a change. Kinda wish I hadn’t sold the C5 as I’ve have had a sequential run. My old C5 is on eBay just now but Cheryl says that it’s not a good enough reason to buy it back.
The C3 we’ve owned since new in 2009. It was my Gran’s car until she passed away. My Mum has been using it since as she loves how small it is to park when shopping As I moved it to wash it earlier, it ticked over 15k miles. Unfortunately it got bumped in a carpark a few months ago. Thankfully, most of it polished out other then the scuff on the rub strip and it’s left a slight crease in the door.
The C4 has been Cheryl’s daily for 2 weeks shy of 12 months. I still love the colour on it when it’s clean.
Then there’s the C6. Since I fetched it back from France and had the gearbox rebuilt, it’s been superb. Despite lockdown, we’ve covered 3500 miles in it since December. There’s a nice run up here that takes a couple of hours and covers around 70 miles. It’s a nice mixture of A roads, B roads and some dual carriageway on the way home. It gets the cars warmed up properly when we take them on the route.
I managed to get a couple of my non Citroens washed as well. If I can get 2 more cars done next weekend, everything will be nice and shiny. :)
David.
x 378
Post by RichardW »
All looking tidy, David!
The AdBlue pump seems to be a problem on early Blue Hdi cars - PaulR is just in the process of doing his on his 308 - God only knows what they were on when they thought making the pump and the tank all one piece was a good idea!!
Mandrake
x 343
Post by Mandrake »
I'll be interested to see what you think of the CrossClimate+'s David.
You might have seen in my blog I put some 215/50/17 CrossClimate+'s on my Leaf recently and I Kinda regret it. The ride is really harsh compared to the summer tyres they replaced, I think due to the XL load rating which makes the sidewalls extremely stiff and non-giving, certainly in 215/50/17 form factor. Every tiny surface imperfection passes right through into the body.
When I press hard on the sidewall with a thumb they hardly deflect at all - when I press hard on the sidewall of the Xantia tyres (205/60/15 Michelin Energy Saver) they have a lot of deflection even at the same pressure.
I've dropped the pressure a bit to make them a bit more palatable but I'm either going to sell them on after the winter or perhaps get a second set of (smaller) wheels to put some more comfortable and quieter summer tyres on during the middle 8 months of the year and keep the CrossClimate+'s as a dedicated winter tyre... probably the latter.
Donor 2019
x 1282
Post by mickthemaverick »
Simon, taking into account your intention to get summer wheels and tyres might it not be an idea to go and see a nearly new tyre dealer and swap your Crossclimates now, while they really are nearly new, for a set of decent nearly new winter tyres to give you comfort now instead of waiting until spring? :)
DHallworth
Donor 2016
x 63
Simon - I was reading your blog about the Cross Climates and am really surprised. I’ve had them on my 407 Coupe for a while now and have recently put them on my Range Rover as well and can’t say I’ve noticed any difference. They’re on the C3 in my pictures too. A friend of mine has them on his Kia Soul EV and is now on his 2nd set of them as he rates them very highly. I’d fit them to anything these days I reckon.
DHallworth
Donor 2016
x 63
The new Cross Climate tyres are on the C4 now. It feels nice to drive, the road noise has reduced from the Hankook tyres that were on it previously. I can’t say I’m noticing any difference to the ride either.
All in all, it’s nice to have the car on some new tyres. Despite us only have had the car for 11 months, the 2 good tyres were dated 2016 and the 2 older tyres were dated 2015.
David.
Mandrake
x 343
Post by Mandrake »
CrossClimate or CrossClimate+ ? What size are they and are they XL rated ? (I think some of the smaller sizes are available in non-XL, but not the size I need)
DHallworth
Donor 2016
x 63
They’re Cross Climate+, they’re 205/55/16 V and are the XL rated ones.
Did you see my post on your thread? I’d be tempted to try the PS4S’s if I was you.
David.
