Ah, that blows that theory out of the water then, it won't have an oxygen sensor if unleaded petrol wasn't available.xantia_v6 wrote:A 1988 car probably doesn't have an oxygen sensor, as 98 octane fuel in the UK still contained lead at that time.
Mandrake wrote:Ah, that blows that theory out of the water then, it won't have an oxygen sensor if unleaded petrol wasn't available.xantia_v6 wrote:A 1988 car probably doesn't have an oxygen sensor, as 98 octane fuel in the UK still contained lead at that time.
David said he's already changed that...xantia_v6 wrote:Definitely change the fuel filter...
Only easier if the top of the fuel pump is accessible without dropping the fuel tank.CitroJim wrote: Even easier to check than using a pressure gauge on the fuel line, just put a voltmeter across the fuel pump supply and see if it's maintained...
AEI ? What's that ?DHallworth wrote:Someone on the CCC forum in the CX section has said he reckon this is either a split pipe or a problem with the AEI.
Sure, but that doesn't test for wiring problems from the fuse to the pump causing the pump to run slow or intermittently...(such as a bad earth return near the pump - look at that fuel gauge jumping up and down!CitroJim wrote:No need to get right to the pump, just check the supply at the fuse... Or even listen for the pump running![]()
The service manual says its a Bosch "LE Jetronic".Is the injection system Bosch LU2 Jetronic? Sounds like it might be if it has a 'flapper' AFM...
Will the engine keep running if the throttle is held open...
A lot of problems, if it is LU2 Jetronic, were caused by air leaks anywhere south of the AFM...
Yes, precisely as I said...Mandrake wrote:It sounds like hot idle speed may be set by an idle screw on the throttle instead of being ECU controlled like more modern cars ?
Sorry, I must have overlooked your comment on the brass screw.CitroJim wrote:Yes, precisely as I said...Mandrake wrote:It sounds like hot idle speed may be set by an idle screw on the throttle instead of being ECU controlled like more modern cars ?![]()
