ABS Warning Light Staying On!!
- My Cars: Citroen C8
To DickieG
Apologise if you have emailed me your contact details but I think I may have deleted your email from my spam folder by accident!
Please reply
Thanks Brady
Please reply
Thanks Brady
Brady
Citroen C8 2.2 HDI Exclusive 2006/06
Previous French cars -
Renault Megane Tourer 2004/54 1.9 DCI Privilege
Citroen Xantia 1998/S 2.0 16v Exclusive Automatic
Renault Laguna Sports Tourer Dymanique 2001/51
Citroen Saxo VTR 2000/W
- CitroJim
- x 6204
- Contact:
Yes, I'd agree Peter, check the connector. You'll find it nesting on the front side of the rear part of the subframe up by where the brake flexi-hose is anchored to a bracket on the subframe.
It gets covered in oil there and they do occasionally drift apart.
If not that then a change of sensor. Not too bad a job on the front. That one is the easiest...
Good work Brady
Good work Brady
CitroJim wrote:Yes, I'd agree Peter, check the connector. You'll find it nesting on the front side of the rear part of the subframe up by where the brake flexi-hose is anchored to a bracket on the subframe.
Good work Brady
Brady
- CitroJim
- x 6204
- Contact:
Sorry Brady, fast typing and not thinking leading to confusion!
I was agreeing with Peter N that the connector was worth a check and then drifted to telling you where it is located without really making it clear who I was speaking to...
I think I'm going to have too meet up with one of you forum guys sometime soon and have a few lessonsCitroJim wrote:Sorry Brady, fast typing and not thinking leading to confusion!
Brady
Hi Guys
OK I don't want to jinx this one but from today the ABS warning light has gone off and stayed off (so far anyway, touch wood!!)
why would this be? seems strange to have a intermitted fault on the ABS. Should I still go ahead with the O/S/F sensor change or just be wary of it for now?
Brady
- CitroJim
- x 6204
- Contact:
It does sometime happen like that Brady but so often it means the sensor is not entirely happy.
Have you checked its connector?
Also, have a look at the sensor itself and the ABS toothed ring on the driveshaft joint. Give the ring a clean up and remove any debris from its "teeth" and also clean the very end of the sensor where the pole-pieces are.
Not a bad idea to get a spare in stock but be aware that MK2 sensors are different from MK1 sensors.
ABS light back on today I'm not a happy boy
Looks like I'll have to buy the sensor after all
Brady
- VertVega
- x 13
ABS light was my nightmare for sometime and it is very annoying.
Using pic which is sent by CitroJim you can measure the resistances.
It seems that front left is not giving normal readings. If they are between
1030 - 1080 Ω then it can be regarded as a healthy reading.
Before replacing it, you should also measure from the sensor connector.
Sensor cable is about half a meter long, follow it to find the connection point.
It's route is almost same as the handbrake cable route.
___________________________
PS: I have unplugged the ABS ecu connector several times (~50 or more)
and without disconnecting the battery negative plug
I didn't know that it should be disconnected.
Fortunately it didn't cause any harm to the ABS ECU.
- CitroJim
- x 6204
- Contact:
Just me being very cautious around automotive electronics...VertVega wrote: PS: I have unplugged the ABS ecu connector several times (~50 or more)
- VertVega
- x 13
Disconnecting battery is definitely the correct and proper way for this.
I had the "good luck" of a novice
I don't have to worry about any security codes, radio code but some cars do.
Only radio needs a new station scan and clock time must be set again
- My Cars: Currently:
In the past: 3, CX td Safaris and about 7, XM td estates. Lovely cars. - x 1207
If you are getting any resistance reading at all from the sensor the chances are that its OK, when they fail they normally go completely open circuit so you get no reading at all or one in the 'megohm' range due to leakage, if the resistance is only slightly high its most likely a poor connection.
- Xaccers
- x 184
Funny you should say that though, one of mine was showing 1100Ohms measuring the sensor directly.Peter.N. wrote:If you are getting any resistance reading at all from the sensor the chances are that its OK, when they fail they normally go completely open circuit so you get no reading at all or one in the 'megohm' range due to leakage, if the resistance is only slightly high its most likely a poor connection.
Replaced it with a new sensor and all was well.
DIY sphere tool
DIY sphere tool
