Thanks Xac, I knew someone would say that . Yes Malcolm, it's the auto tensioner for the aux belt. I have undone both the top & bottom spring bolts and removed the tensioner assembly - all except for the centre shaft which is still stuck solid. I guess I'll have to do as Xac says but I have been trying to avoid the extra work...Xac wrote:You'll have to remove the plate it and the pump etc are fitted to.davek-uk wrote:Sorry to grab the thread - although it's finished.
Am I the only poor sod to have a problem?
I have the aux tensioner off all except the centre bearing spindle. And that seems solid. I can't turn it or pull it out or knock it to-and-fro with a lump hammer. It's solid. Any ideas?
Not a hard job, just a bit long winded.
Dave
