front caliper pivot bolt cracked
My Cars:
x 92
Post by citronut »
Anders were did you find the calliper slide pins for a pound each,
the part No. you mention 96130031 is the calliper carrier bolt
as i have just checked on service citroen,and they list two slide kits
(1) 4448.68 31.10 UK pounds
(2) 95667821 37.28 " " "
trade inc VAT
Candy if the ends are split it will only be were the torx tool fits, and for replaceing pads you dont need to undo this slide pin/bolt.
regards malcolm
AndersDK
My Cars:
Post by AndersDK »
citronut wrote:Anders were did you find the calliper slide pins for a pound each
Thats exactly the problem malcolm, I did not found them, as something is rotten in D.... :roll:
Its the caliper mounting bolts that sells at some £1, and the rear pads pin bolts that sells at some £1.5.
Anders (DK) - '90 BX16Image
candy
My Cars:
Post by candy »
citronut wrote: Candy if the ends are split it will only be were the torx tool fits, and for replaceing pads you dont need to undo this slide pin/bolt.
regards malcolm
we were going to change discs and clean the calipers and pistons up as well but doesnt matter now as front pads and discs will last at least another 12 months just wanted to change the lot whilst we had it on ramp
http://s143.photobucket.com/albums/r124 ... %20xantia/
Teresa
1996 Citroen Xantia 1.9 TDLX silver
2004 Honda cg125 red
Post Reply
