Ah thats a shame, how did you manage to do that? The 2.1TD manual estates are quite rare models, does Peter.N not want it I didnt think you liked diesels Andrew, or estatesandmcit wrote:Yeah, I made the mistake of buying a green series 2 estate 2.1 manual.
150k and good straight body but within a day of first using it I managed
to burn out the clutch and swipe the front end off damaging the front
bumper, grille and lights... must be green cars being unlucky or
somesuch. Not sure what I'm going to do with it. I believe the engine
is good but may have iffy cooling.
Oh a TCT, it does sound very nice, is this one you use or is it stored? I like the interiors in the base models.andmcit wrote: Yes, the L plate is a 2.0 TCT base i trim spec - how's about that!?
I love the colour and it's the reason I got the car.
I think the rust in the footwells is usually cuased by the drain hole in the scuttle panel being blocked. Water slowly leaks down and causes it to be kept wet. Ive seen this on a couple actually.andmcit wrote: Sadly not at the moment, the red VSX was having some remedial surgery
required for an MOT attended to on it's front nearside footwell where the
whole outer skin has dissolved away as well as a pair of patches are needed
on the sill where some scumbag threw a brick at the screen - I've had to
park it off the road and SORN it whilst I plan my next move as it's going to
be expensive sorting it without MOT/insurance although I do have a spare screen.
The black Exclusive has a very unhelpful habit of shedding it's aux belt
at the most inopportune moment and is very unreliable as a consequence
despite a check out of pulleys and new correct length belt. Again, I'm really
awaiting the decent weather and perhaps more motivation to crack that one
although I'd like to get my KYAC (snapped off x2 wheels) normal towcar
2.0i TCT sorted first and if that's terminal the black Exclusive will HAVE
to get sorted. :X
Is the black Exclusive a TCT too?
Have you made any more progress with your KYAC? Ive not checked on the Xm forum for a while now, i know you started to fix it.
Chris.
