Hi endorfin
With my above answer I only covered the changes at the injector pump end.
Those two options were keypad controlled.
To improve security further there was a later change made.
Instead of fitting the keypad the security number was coded in a minature computer chip and circuit that was embedded in the car key body.
The car has a coil wound around the ignition switch and the code is automatically read when the ignition switch is turned. The code read must match the one stored in the ECU or the device on the injection pump.
If you are fitting one of the later injection pumps the armour and any security device needs removing, The injection stop solenoid then needs a direct feed the only downside being that the car will no longer have immobiliser security fitted.
John
immobiliser wont accept new fuel pump?
I have had a similar problem with the Lucas injector pump on my 206 1.9d
To cut a long story short - I have de-armoured it and taken out the solenoid completely.
Now I am having a god-awful time trying to find a replacement solenoid!
Having spoken to Lucas themselves, they told me that Peugeot fitted different solenoids that have a longer 'stroke' on them.
All the 'durite' solenoids I have tried so far will not open far enough to allow diesel to flow through the pump!
Does anyone know where I might be able to aquire a suitable replacement solenoid?
Many Thanks in advance!
- spider
- My Cars: Soon, I hope...
- x 77
- Contact:
That's the first time I have heard of that.
I'd half suggest you start a new topic about this so it does not get overlooked. I am very surprised to hear this though, as that pump and engine is shared with a few other vehicles (probably the most popular one on here being the Berlingo van)
Have you tried a standard lucas stop solenoid (the usual type you fit to the XUD engined models)
Andy.
