immobiliser wont accept new fuel pump?
- My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising - x 71
if only i had the time to wait for this advice, i have jus swaped the pumps for and older one. i really cant be assed with making another jouny back to the scrappy to swap back to im gunna try my luck.CitroJim wrote:Yes, if the throttle cable is supported by the armour. It can be replaced and you can replace the shear screws with normal ones.
If the pumps look totally different then you're likely looking at a Bosch. Not a straight swap.
Also, if you look at an earlier Lucas pump, it may not have the turbo overfuelling disphragm and cold start advance solenoid.
I think you're best off de-armouring what you have. It really is not too bad a job.
the pump i now hove has turned out to be a bosch ( couldnt tell till i got it out) how ever it appears to have the revalvant cable slots and a vacum thing that attaches to the intercooler.
i am currently moving the studs round to fit the new pump, how ever i didnt think to take the injectors. will it not run at all with out?
- Xaccers
- x 184
If memory serves, you'll need the injectors and their metal pipes for the bosch as it squirts in a different order to lucas so the pipes go to different injectors.
DIY sphere tool
DIY sphere tool
Injectors are in the same order, 1 3 4 2 its the output from the back of the pump on a Lucas thats different, and yes the pipes will be different!
Well remembered Xac, even I forgot about the pipes then selfes when I mentioned needing Lucas injectors!
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
The Lucas injectors are a differant presure setting to the Bosch
Lucas = 145 bar, Bosch = 175 bar.
Useing Lucas injectors on a Bosch pump will put the pump timing out by some way, this can sometimes work if you adjust it by ear but it will never be quite right.
You will also need the sprocket for the Bosch as the Lucas one will not fit.
99 406 LX HDI 90 estate
99 C250TD sport estate
01 306 HDI 90 meridian estate
Brew my own biodiesel
http://www.shorewasteoil.xtreemhost.com/" onclick="window.open(this.href);return false;
Don't you just hate that! Someone gets answers here but doesn't post a conclusion
Also don't you just hate typing out a long description of your problem then accidentally deleting it....that just happened to me! So here goes again....
I'm a newbie here, fresh over from the vegetable oil diesel forum..
I have a 1996 Citroen ZX TD Volcane with a LUCAS fuel pump but I'd like to be able to run it on the regular supply of used veg oil that I've inherited so I want to fit a BOSCH pump.
I've been offered a bosch pump, mounting bracket, injectors, pipes and conections and the wheel for the timing belt with woodruff key off a 1998 Xantia for £75 inc postage (good price) but I'm concerned about the immobiliser issue. I read some comments in this thread that say the code is stored in the ECU and others saying its stored in the pump itself. The 96 ZX with the Lucas pump has a keypad immobiliser and alarm.
My local mechanic has said he will do it for £80 changing the cam belt at the same time, seems a fair price to me? Only thing is he says he's not done one before and can't guarantee it'll work which doesn't inspire me with confidence!
Any advice on a step by step procedure on this, I promise to post a full and detailed conclusion at the end of this!
I found a site showing how to remove the armour on the Bosch pump, thought I'd post the link here in case anyone else would like to know:
http://www.eastment.net/boschpump1.htm
Hi endorfin
You asked about the storing of the immobiliser code.
If the car injection system is electronically controlled this is usually done using an engine ECU. It is very easy and cheap for a manufacturer to add an extra bit of immobiliser code to the controlling programme. This enabled the keypad to talk to the ECU. With this type of installation the immobiliser code is stored in the ECU. This type of early immobiliser design and is fairly easy to neutralise or circumvent.
Many of the earlier IDI diesel engines had a simple mechanical injection pump. So the engine did not need or have an engine ECU. For a long time these cars were made with no immobiliser protection. When immobilisers became virtually mandatory as part of the "stop car theft game" here was a design that had to change. The manufacturers simply made a little tiny ECU with just the immobiliser code routines in it. They bolted this to the injection pump and covered it with armour to slow down bonnet opening thieves making it far more secure.
John
John
Xmexclusive
