I didnt mean for glow plug operation at all i meant for fuel air mix as this changes slightly with outside air temp being such a large range.
Nice one with the dirty contacts in the drivers side electric window switches they are now working perfectly both up and down.
c5 temperature reading
reading for mixture
c5 hdi 110 lx
Xantia hdi forte 140,000 [sold]
Yep, the Outside air temp sensor has nothing to do with fueling or running of the car (did you notice the car running any differently ?).civvie wrote:Wheeler,
You trying to tell me that garages tell porkies!!
Steve(':roll:')
It can however effect the operation of the A/C.
The glowplugs use engine temp info from the coolant temp sensor.
The Fueling/running uses info from both the coolant temp sensor & the intake air temp sensor which (as myglaren says) is a part of the MAF sensor, well on the HDi's anyway.
