2 little known features of Xantia's , I think !!
So what is the steel wrench type thing stuck in the bonnet towards the window on V6 mk1 ? I haven`t had time to pull out for a look as been doing other stuff.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
- My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising - x 71
Jim, I'm positive your V6 has the indexed mirror.
I clearly remember it moving when you took me for a spin in it.
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
Previous:
- CitroJim
- x 6204
- Contact:
If it's in the passenger side corner and the back, that'll most likely be the towing eye. Some were located there and other times they were packed in with the jack in the spare wheel...lexi wrote:So what is the steel wrench type thing stuck in the bonnet towards the window on V6 mk1 ? I haven`t had time to pull out for a look as been doing other stuff.
- CitroJim
- x 6204
- Contact:
Thanks Toby That's brilliant!Toby_HDi wrote: I clearly remember it moving when you took me for a spin in it.
Guess I'd better make a new years resolution to visit the optician then. Never noticed it
I'd had my Exclusive for a year before I noticed it
Now using '00 Xantia LX HDI, pov spec
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident
'99 Xantia HDI 110 Exclusive, RIP
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped )
& a couple of Peugeots !
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
- Sara Watson's Stalker
- Location: NEW South Wales, Australia. I'll show you "Far, far away" ;-)
- My Cars: Peugeot 605
Citroën Berlingo
Alfa 147 - x 93
Bruce H parted out a non-dipping, single airbag Exclusive (Series II). So, they do exist!
I joked it was "exclusive" of the features one came to expect.
Has anyone experimented to see if the motor unit can be transplanted between dipping and non-dipping mirror shells? I mean the inner bit which is about size/shape of a boot polish tin.
- My Cars: 07 Citroen C6 V6 HDi Exclusive - Red
07 Citroen C5 HDi VTR - Red
09 Citroen C3 1.4i VTR - Silver
01 Citroen Saxo 1.1i Forte - Mango Orange
93 Ford Mondeo 2.0i GLX
19 Hyundai i10 - x 110
Dipping mirror is a great idea, the VSX Xm has that, very handy that you can adjust it when in reverse. I often adjust it for parking next to curbs.
19 Hyundai i10
19 Hyundai i10
- xantia_v6
- Lexia Available: Yes
- My Cars: -
1997 Citroen Xantia V6 (France)
1999 Citroen XM V6 ES9 (France)
2011 Peugeot 308 CC THP 155 (NZ)
1975 Jaguar XJ-S pre-HE (NZ) - x 835
Yes, I have converted a non-dipping to dipping to reinstate the dipability on my Mk2 Xantia. The wiring needs to be swapped over, which is a bit tricky.addo wrote: Has anyone experimented to see if the motor unit can be transplanted between dipping and non-dipping mirror shells? I mean the inner bit which is about size/shape of a boot polish tin.
Mk1 and Mk2 dipping mirrors have different means of connection to the boot polish tin, the Mk1 being soldered (you can only get to one side of the PCB), and the Mk2 having a convenient multi-way connector (which is not compatible with a Mk2 non-dipping mirror).
The boot polish tin is interchangable with one from a Jaguar XJ40 (soldered connections like the Mk1), but you need to cut a couple of tracks on the PCB, as they have different wire links fitted (and as above, you can only get to one side).
Citroën Berlingo
Alfa 147 - x 93
C'est interessant. My non-dipping X2 mirror (now replaced with Bruce H's non-dipping Exclusive one) has a three pin socket on the "boot polish tin"; are you saying the dipper has a different plug again?
One (non-mirror Q) that confounded me: I found yet another redundant plug in the harness. It's on the driver's side of the front footwells, strapped with foam tape to the main cross-car harness. Two pin plug, with largeish terminals, reddy-brown in colour. I wondered if manual cars have any switches on the clutch pedal.
- xantia_v6
- My Cars: -
Yes, it has an 8 way connector (standard 2x4 0.1" square pin format). Plus 2 for the heated mirror, plus 2 for the temperature sensor, makes 12 wires all together (the Mk1 only has 10 because the temperature sensor is on the other side).addo wrote:C'est interessant. My non-dipping X2 mirror (now replaced with Bruce H's non-dipping Exclusive one) has a three pin socket on the "boot polish tin"; are you saying the dipper has a different plug again?
Isn't that the diagnostic plug?addo wrote:C'est interessant. My non-dipping X2 mirror (now replaced with Bruce H's non-dipping Exclusive one) has a three pin socket on the "boot polish tin"; are you saying the dipper has a different plug again?
Not hidden I doubt it.. it will be for something thats obviously not fitted to your car but the car used a "Standard" harness..It could be a plug for electric seats, or even the headted elements..
Actually, it could even be the connector from the brake switch for the CRUISE CONTROL knock off when the brake pedal has the cruise switch fitted..
just a guess..
Paul
just a guess..
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
