Melted battery lead (Urgent)
scoles
My Cars:
Post by scoles »
lexi wrote:
Lets just say it was a factory in Wales
Your unit is from that factory :shock:
Am i missing something here?
Was there issues with alternators from a certain factory?
And is that you saying my unit was from that factory? :?
Cheers
Stuart
Brigsygtt
My Cars:
Post by Brigsygtt »
Sorry for bumping an old topic but my current hdi has been playing up, slow starting/gauges flickering etc.
I popped the bonnet today to test the new battery i bought recently, the positive wiring to the batt has melted, although not as bad as the pics on page 1 but the insulation has gone & will need replacing, the terminal has melted a little too.
I have checked the alternator and its showing 14.4v. The positive terminal seems to be a little bit loose & wiring isnt hot when running, could the loose terminal have fried the wiring??
97 Xantia 1.9 td lx with a/c (Daily, 172K, FOR SALE)
98 Xantia Hdi Lx with a/c (105k)
97 Renault Extra (c1j turbo 230+hp, 12.88@106)
91 Renault 5 Gt turbo (68k minter)
My Cars: Currently:
In the past: 3, CX td Safaris and about 7, XM td estates. Lovely cars.
x 1206
Post by Peter.N. »
Any loose connection will generate heat as it causes a high resistance in the circuit. The starter draws several hundred amps so a drop of two volts could give you half a killowatt of heat! Your alternator voltage is OK but again the charging current can be 50 amps or more when the battery is low which can also generate a lot of heat, a new cable and connectors should work wonders. Do grease the terminals though and any other connections you repair, this will prevent further corrosion.
Brigsygtt
My Cars:
Post by Brigsygtt »
Thanks for the reply, will renew the lot as it looks pretty bad.
Am i right in thinking some of the wiring goes to a terminal block under the big fuses?
My Cars: Bluebell the AX, Polly the C3 Picasso, Pix the Nissan Pixo, Propel the duathlon bike, TCR Pro the road bike and Fuji the TT bike...
x 6203
Contact:
Post by CitroJim »
Yes, it does. Ring terminals and 8/10 mm nuts.
Brigsygtt
My Cars:
Post by Brigsygtt »
Ideal that makes it a little bit easier to renew.
Just had the car running, starts fine now the terminal is flogged up but the wiring is still getting fairly hot although i can touch it without burning myself :shock: Could be a short somehwere?
My Cars: Currently:
x 1206
Post by Peter.N. »
Heat will travel quite a long way down the wiring but the hot point will always be a connection, unles the cable is damaged.
Post Reply
