Who says that ABS equiped vehicles take longer to stop on snow? The only scientific study I have been able to locate for this subject the NTSA test referenced by wikipedia didn't do tests on either ice or snow, the nearest surface that would approximate this was wet grass and the results for that were not conclusive. I would also have reservations with respect to their tests on gravel which at 2 inches depth was closer to a sand drag then a normal loose gravel road surface.DickieG wrote:The correct reason behind and ABS equipped vehicle taking longer to stop on snow or gravel is that without ABS, locked wheels cause a build up of debris to form ahead of the locked wheel which effectively becomes a wedge and causes additional friction hence the shorter braking distance than a car equipped with ABS where the wheels continue to roll over any debris hence no wedge.
While I can accept that on a gravel surface the nature of gravel forming a wedge under a locked wheel a plough in effect may give better braking than ABS I can't accept the same argument for snow the dynamics of which including the propensity to turn to water under pressure are very different and it doesn't tie in with my own observations.
Yes I would agree with that it can be very alarming first time even if ready for it, I personally think that there is an increasing compelling argument to put drivers in a simulator as part of their training but I guess that would deserve a thread of it's own
I think that in some of the posts above there is a little confusion between ABS and ABD. Extensive research of real life collisions has shown that one of the strange things that regularly occurs just prior to impact is that the driver does not apply maximum braking just prior to impact despite it being obvious to the driver that they are about to suffer a serious or fatal injury. It is due to this fact that Brake Assist, ABD (Assisted brake distrubution) or whatever a manufacture wishes to call it was devised, this system senses the manner in which the brakes are applied and then applies maximum braking if the driver fails to do so. When first fitted to cars (IIRC Mercedes was the first) there was a tendency for the system to be "over active" with drivers complaining of the car doing emergency braking when not requested. With improvements in technology this issue has been resolved and just like car stability systems the newer the car the more effective they are in real life situations.
At work I drive high end high performance cars and the difference in the operation of the newer systems is quite significant, with the latest being very subtle and very effective.
One thing to bear in mind with ABS is that there is a large proportion of drivers who have never felt what happens with ABS when it is activated (the pedal juddering and bouncing up and down) which can frighten some drivers and cause them to release the brake pedal, another reason why ABD has been developed.
cachaciero
