I have a problem
bottom tensioner with 6mm hex L shape (screw at the bearing)
damage, my hex key slipped
my was that tight, my mechanic put it back very tight, knowing it already show a damage mark. Now it wont budge, hex key with spanner as extension
how can i force it release it free
I want an aux belt change, the cover missing somewhere causing belt's premature fatigue
URGENT HELP NEEDED!!!! Xantia TD Aux Belt Replacement
- My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising - x 71
If the head of the bolt is damages, theres no alternative but to drill the head of the bolt off, and remove the lower bolt, remove the tensioner pully and then unscrew the rest of the drilled bolt out, and replace with another one of similar length, OR the rough way, get a Star shaped Torx adapter, and BASH it in with an extension bar and undo it that way..
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
