Xantia HDi timing belt snapped WHAT HEADGASKET????
scoles
My Cars:
Post by scoles »
by make sure its tensioned properly? did you have problems?
looking to get all the info i can and get it done for next weekend i think.
Stuart
Toby_HDi
My Cars:
x 3
Post by Toby_HDi »
I fitted a kit and tensioned it, the official way is to use a SEEM gauge but I tensioned it by making sure I could just twist the belt about 90 degrees on the longest run.
I then put it all back together and a day later it slipped.
Best to tension it up and then reassemble without the cambelt cover, leave it idling for an hour or so (so that it gets up to temperature) and check the tension again. If it's too loose you'll be able to twist it further than 90 degrees. Once hot, if its too tight it'll likely start squealing.
Plenty of help on here once you start tackling the job.
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
scoles
My Cars:
Post by scoles »
Thats the parts just ordered now, went to euro car parts counter tonight after work only to find it was £30 more expensive to purchase over the ECP counter than it was to buy it from their website :(
So came home and ordered them. the thinest head gasjet they had on their site was 1.4mm and i am sure the 5 notch gasket is 1.5 mm and the current gasket that had been fitted was four notch.
so am i right in saying the 4 notch is 1.4mm???
Cheers
Stuart
Post Reply
