Here are some cheaper ones:-john alexander wrote: AND IF IT NEEDS A FILTER £600.
http://www.buypartsby.co.uk/diesel-part ... ke=CITROEN
Hmmm! not good news then. I did research this a couple of years ago when I thought that my C5 might need them. Fortunately not, it seems.citronut wrote:Steve wrote
"The filters are around £145"
my local pug dealers parts manager told me that is what they charge for afillter, but he thinks those are factory re/con units at that price as when they come in the metal parts of the body have surface rust on them
regards malcolm
The flow sensors will indicate a fault as there will be insufficient resistance in the filter.Monkeyfeet wrote:re: knocking the filter out. I'd love to do that, fully agree with the above post. Has anybody successfully done this? ie no warning messages afterwards. I'm sure I remember it being tried but having probs with reprogramming the ecu's
The sensor does indeed measure the difference in pressure as opposed to flow, I measured a fairly new filter & the pressure difference was 5mb at idle.cachaciero wrote:This topic has gone around before, there is at least one person on this forum who claims to have done this with no problems, as regards the system being able to detect lack of filter there was some doubt expressed as to whether it would, I think it was wheeler who actually checked the pressure across a new filter and found the pressure diff to be very low.
Regeneration etc is managed almost entirley by the injection ECU, the differential pressure sensor & cat temp sensor are wired directly to it. The FAP ecu only has a 16 pin connector & deals with injecting the additive & monitoring the additive level, the only direct inputs it really has is the fuel cap sensor & additive level sensor, all its other info comes via the multiplex network.cachaciero wrote:As far as I can ascertain the engine ECU is not concerned about the pressure drop across the filter the diff pressure is only monitored by the FAP ECU. On the 2.2 at least you can tell the system that a FAP is not fitted this will inhibit the automatic regeneration cycle.
