New update for you as I'm waiting for the snow to clear,
Got my wheel stud and bolt + my new steering rack gaiter from Nissan the other week, so when they arrived i nipped out to the car and raised it up onto some Axel stands, whooped the wheels off and got to work.
Had to remove the caliper so i could get the brake disk off to replace the wheel stud, in the process snapped the brake line to the caliper. so i replaced the wheel stud, and ran down to my local tyre place and got a new brake line made up. came home and replaced it, then tried bleeding the brakes, what a nightmare that turned out to be. half way through thought id give it a rest and have a go at the steering rack gaiter renewal.
I think that has to be one of the easiest jobs on a 300zx lol, undid the arm with the nut still where it should be, then undid the nut once the arm was off, and just slid the old one off and the new one on. put the nut back on to where the rust stopped it, then put the rod back into the lower steering rack arm and did it back up, tracking is still perfect
Anyway back to bleeding the brakes, i had to wait a few days for the rain to stop, plus half way through the misses had our new baby boy Wesley.
Once we were all back home, i raised the car again, and took all the wheels off, i then had to bleed the ABS unit in the boot area first, then the fronts then the backs, used about 1lt of brake fluid in the process with another bottle sitting by just in case. well all i can say is the car stops on a dime.
two more things left now, a spot of welding that needs doing (2inch gash and a 2p size hole), and replace a hi pressure power steering pipe, and I'm all set.
