I now again have working aircon. New OE fit drier (Coolking brand; Taiwan) and some hoses were remade.
Leaks of LHM had damaged the high side hoses between R/D and the TX. I had the flex parts remade in Galaxy thinwall, and we added two threaded unions - one adjacent to the TX, and the other above the doseur. This way, if/when the low side needs remaking it is far simpler to detach.
WARNING: The garter spring hose coupling behind the offside upper mount tower is a right bugger, even with the special releasing tool.
Low side gauge pressure is around 45 inches (positive) - while oddly high, I am assured this is common for the SDV716 type compressors - aircon bloke is not in love with them at all.
Some pictures:
cost of matrix replacement
Re: cost of matrix replacement
hi, on page 2 the description of matrix removal says disconnect glovebox light whereas Haynes bol says remove glovebox, is this necessary please? this is a S2 Xant.
Ed
'63 Renault Caravelle - stored
'99 Xantia 1.9TD Estate - matrix done:))
thanks Addo, i have removed the screws above and to the side of the glovebox but can't locate how to release the bottom... any ideas please!
Ed
iirc there's some in the carpet of the glovebox
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2006 C3 1.6 HDi SX,
1971 D Special
2006 C3 1.6 HDi SX,
A 1/3 of Team WFA 'Clarkson'CitroJim wrote: I'm a pink fairy
shall check it out.. weather permitting!
Ed
yep moved carpeting and screws were revealed thanks!
everything removed but the dash will only pull out about 4cm on both sides and no further
it's almost as though something in the middle is fouling but i can't see/feel anything... any suggestions would be welcome please
Ed
with the use of 'reasonable force' it came out
Ed
- My Cars: Currently:
In the past: 3, CX td Safaris and about 7, XM td estates. Lovely cars. - x 1207
How would using your aircon evaporator as a heater work, does it have enough surface area? Obviously you would loose your aircon but a heater is more important - well to me anyway.
I wouldn't go down the road of electric heating, a normal car heater has an output of about 3-5Kw that would represent a current draw from the battery of around 300-500amps, you would need a pretty big battery and alternator to supply that.
- Skull
- My Cars: Citroën Xantia XII HDi
Citroën sAXo XII
Missing AX 1.4D Echo - x 225
Ahh there you are
It was like trying to find the real MATRIX
Ta RichardW for the thread directions
On my 4th Citroën Xantia (X2 HDi (110))
Citroën sAXo Memphis Mk II
Gone
Xsara HDi VTR Coupe / Saxo 1.1i / BX 1.9 d / 4 x AX's (1.4D /1.5D)
2 x 406 (1.9 TD Estate/2.1 TD Saloon) 405 1.9 D Estate 306 1.9 XTDT Hatch
Gone
To me aircon is more important as it dries the car out and speeds up demisting.
Warming up is easier than cooling down in my book
- VertVega
- x 13
Decided to add pics here. I hope it will be useful for others who need help on Xantia Heater Matrix.
In order to remove:
1. move the metal clip to the right with your thumb in the arrow direction (see pic).
2. when the locking part is free, still keeping your thumb on the clip (forcing it to the right side)
3. at the same time pull equally both hoses off (pull towards the engine)
Also heater matrix pics I have taken from a scrap Xantia (LHD).
You can make a mirror image of these for a RHD Xantia
In order to remove:
