Not if you follow the instructions but the option is there... Good luck!jgra1 wrote:guys would that wipe the C drive? ..
I am happy to try it if not...
win2K problem
I've managed to get out of trouble a few times using automatic repair. It analyses the disk and may or may not offer you the repair choice depending on what it finds. Be careful not to choose the "install a fresh copy" option as this will delete your existing settings including user accounts if the advisory messages are to be believed. If everything goes well you should find your desktop and emails etc as they were before the disaster. Hopefully you should also be able to log on as well.
Another option might be to upgrade the existing Windows 2000 installation to XP. I did this very recently and my desktop, emails, etc were imported to XP exactly as they were under 2000.
David
BX19TRS 120K E Reg 1992-2013
BX19TRS auto abs 96k F Reg
BX19TXD 150k K Reg
BX19TXD 150k K Reg
Onlinemyglaren
- My Cars: Mazda 6
Ooops.
Previously:
2009 Honda Civic :(
C5, C5, Xantia, BX, GS, Visa.
R4, R11TXE, R14, R30TX - x 4922
I've run the repair console on XP a few times and it does pretty much reinstall XP but doesn't lose any files but you must be very careful with the options that you chose or it will erase them.MikeT wrote:Good point David but the problem I found with such repair consoles etc is there's no reversing them if they don't work and I've seen some really screwed up systems from it so tread with caution if you're going to try it, John.
AFAIK, it repairs/restores the operating system which IMO, is no different to just installing Win2K again - perhaps a few customisations are kept in the repair process?
Just the same, it would be advisable to slave it to another Windows machine and backup any files you don't want to risk losing.
Note that as Windows has not been properly shut down, you can't use an Ubuntu live CD to recover any files from the drive.
This is a brilliant option otherwise as you don't need to extract the drive and shift it to another machine, just select the files and burn them to a CD* or transfer to a jump drive/external drive.
*Assuming two optical drives!
- CitroJim
- x 6206
- Contact:
I do very regular backups, both of these forums (every day) and all of my data to that quaint old stuff called magnetic tapemyglaren wrote:But the rest of us should 8)Linus Torvalds wrote:Real men don't do backups!
Touch-wood, fingers-crossed, I've not needed them in anger yet...
- x 54
- x 54
Ah, is \\n056pegasus the name of your working laptop or that of the 'broken' PC?jgra1 wrote:I found my installation CD and tried every avenue of repair, but they all got me back to start and no login..
i tried psexec again, and it gave the same report back, even with the PC switched off ?...
Make sure its the broken one.
After a bit of testing over our network im hedging my bets on an authentication error Still worth a try though.
Kev
'19 C4 Cactus 130 Flair
- (Donor 2021)
- My Cars: 2010 C5 X7 2.0 hdi 160 exc auto
MG TF 135
Boxer II 2.2 camper conversion
BMW R1200RT
BMW K1300 R
Honda V F R 800 5thG / MT500 Armstrong - x 39
i have got into the router software, and found 3 DHCP clients.. one is the lap, one is a guy nearby, and the other is ;john; so that must be the PC name of the desktop ?
but did psexec again and
psexec \\john -s net user johnnew /add
Couldn't access john:
The network path was not found.
Make sure that the default admin$ share is enabled on john.
