I'd go along with this if it was just one end of the car sinking but I feel both yours, rpaco and VertVega, are sinking fully at both ends. Unless you have duff anti-sink valves at both ends and/or leaky cylinders at both ends, this just can't logically happen and the chances of two being faulty would be nigh-on impossible.myglaren wrote:Is it not more likely to be the anti-sink valves or a leak in one of the rams?
The anti-sink works like this: Under normal running, the main system pressure holds the anti-sink valves open. When the engine is switched off and main system pressure falls to a value below that contained in the corner spheres, the pressure in the corner spheres snaps the valves closed so that there can be no further leakage from the suspension cylinders via the height correctors. It follows that a duff main accumulator would cause main system pressure to fall very quickly and therefore the anti-sink valves would therefore close very quickly. The efficiency of the anti-sink valves can be tested very easily. Have a couple of passengers in the back. Stop the engine and ask the passengers to get out quickly. The rear should rise and then, after 30 seconds or so, fall back to normal ride height. This shows the there is still sufficient main system pressure to keep the anti-sink valves open to allow a height correction. Repeat but ask the passengers to stay in the car for say, five minutes before alighting to allow main system pressure to fall off. If the height rises and stays high when they do alight, this shows the anti-sink is working as it should as the valve is closed and the height corrector isolated. Repeat for the front although you need a good heavy passenger for this test.
If that test passes then the only thing that can cause a sink overnight is a tiny leak somewhere between the corner spheres and the anti-sink valve. It only takes a very tiny leak.
The other thing that will cause it is a flat/punctured corner sphere (or spheres) which causes the pressure held by the anti-sink valve to leak away slowly.
Another rare cause is that the main accumulator is so good and the system so leak-free that the main system pressure falls very slowly and does not allow the anti-sink valves to close in a timely manner.
Yet another rare cause is very dirty LHM that has left deposits on the surfaces of the anti-sink valves and causing them not to shut off positively. A good Hydraflush should fix it.
