I had the bumper off my S2 Exclusive a while ago (looking to get the same problem sorted). It isn't too bad a job assuming the bolts arn't rusted in
There's the three 10mm ones underneath, a 10mm one each end going sideways into the bumper. Up near the nearside foglight there's a big(17mm?) bolthead. There is a large plastic spigot in the same relative place on the offside (you can't see it).
With all those bolts off the bumper just pulls off the spigot: it needs a bit of a tug, though
There is a multipin connector behind the nearside wing guard
It needs some rags/blankets or whatever on the ground if you are working alone because the bumper comes loose with a bit of a rush.
I think I knocked a float off the low washer sensor or something because the low level light comes on whenever I use the washers!
Windscreen / headlamp washer bottle & pumps ?
OK I'm prepared to stand corrected with regards to the headlight washer mtr. I couldn't see one, and perhaps it was just coincidence that they now work ok.. I am right about not needing to remove anything to do the windscreen washer mtr. tho'.
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
2001 Xantia 3.0 Exclusive
1999 Xantia 1.9TD
1997 Xantia 3.0 Exclusive
1995 XM 3.0 Exclusive Estate
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
Just sorted this problem , it was the headlamp washer pump relay. When I bridged the contacts on the relay socket that feed power to the pump , the pump and washers worked. Before binning the relay I had a close look at the soldered joints under a magnifying glass and discovered 4 of the 5 joints on the legs that connect the circuit board to the socket in the car. Re-soldered them and it all works as normal
Another thing that made me smile was the spray jets raise up so that the spray is directed at the headlights more closely when the washer is operated , then drop back so they don't intrude into the headlamp beam Very Teutonic !!
Now using '00 Xantia LX HDI, pov spec
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident
'99 Xantia HDI 110 Exclusive, RIP
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped )
& a couple of Peugeots !
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
