The crank, shells, connecting rods and pistons have the same part number according to servis.citroen, so I'm not sure how they could have different bearing areas.lolingram wrote:Revue Technique quotes different dwell (I think inlet cam).... also slightly bigger bearing areas around the crank journals.There are some differences between the HDI 90 and 110 internal to the engines, for example, the crankshaft end thrust washers are a different part
How do I convert Xantia 90Hdi to 110Hdi?
- Kowalski
- My Cars: Ex 05 C5 2.0 HDI Exclusive 145k
Ex 97 Xantia 1.9TD SX 144k
Ex 94 Xantia Dimension 1.9TD 199k
Variable vane turbos weren't about when the HDi was developed. it's definitely not a VVT. Boost control is achieved with a very clever vac-actuated (ECU controlled) wastegate.
The 90 is less powerful, less economical and more polluting. The obvious question that nobody has ever been able to explain to me is why on earth they bothered with the 90 in the first place.... I believe the 110 debuted first, the 90 was then cobbled together as a "poverty spec" version of the same engine.
Martin
Old Faithful: Silver V-reg Xantia HDi Exclusive, died due to tin worm @ 259k miles
New Faithful: Silver W-reg Xantia HDi Exclusive, 169k miles and counting...
Previous: Various BX's, XM V6 24,
Venturi Atlantique 300, Alpine A610
I'll look again the next time I can sneak a look at Revue Technique... pretty sure about the cam though.lolingram wrote:
R.I.P. January 2010.
XM 2.1 auto VSX 1996 - Bosch Inj, Xantia HDi 90 estate 1999, Xantia 1.9TD 1997
Previously...
GS 1970, Dyane 1974, Xantia 94 VSX TD, XM 94, 2.1 auto - Lucas Inj, XM 92 2.1 estate - Lucas Inj
Previously...
- My Cars: 2019 C5 Aircross 2litre diesel, auto.
2018 C4 Pic2 Spacetourer auto. Seems nice so far.
2019 C4 Cactus manual. Didn't like it, lots of niggling points. sold.
2011 C4 Picasso excl. - shaping up to be a disaster, bought June 2019. P/X'd
2009 Citroen C5 X7 exclusive, auto, LHD, 207500km (129000miles) now sold
Citroen Xsara Picasso excl. 2004 2.0 Hdi, RHD, 64000miles. (sold)
Citroen C3 Picasso excl. 2016. sold.
Two Xantias, one petrol, one diesel. sold.
In the past: Renault 16 (in about 1977, for a year). With front pass. seat out transported full bathroom suite from Cambridge to Derby!)
Renault 4TL (in 2011, for a year) - x 9
If there the same as the 406 (still PSA so I would of thought so) the 110 has a duel mass flywheel (£200 + to replace) but the 90 is a normal setup.
99 406 LX HDI 90 estate
99 C250TD sport estate
01 306 HDI 90 meridian estate
Brew my own biodiesel
http://www.shorewasteoil.xtreemhost.com/" onclick="window.open(this.href);return false;
- My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising - x 70
- Kowalski
You're right that neither the HDI 90 nor HDI 110 have variable vane turbos, the later HDI 136 (both 2.0 and 2.2) have variable nozzle turbos which accomplish the same job in a slightly different way.Stunned Monkey wrote:Variable vane turbos weren't about when the HDi was developed. it's definitely not a VVT. Boost control is achieved with a very clever vac-actuated (ECU controlled) wastegate.
Audi had variable vane turbo fitted to their 1.9 TD with 11O bhp as far back as '95, and they were not the first to use that technology on a road car.
http://en.wikipedia.org/wiki/List_of_Vo ... DI_66-81kW
- My Cars: 07 Citroen C6 V6 HDi Exclusive - Red
07 Citroen C5 HDi VTR - Red
09 Citroen C3 1.4i VTR - Silver
01 Citroen Saxo 1.1i Forte - Mango Orange
93 Ford Mondeo 2.0i GLX
19 Hyundai i10 - x 110
I think the 90 has a slightly different gearbox? Or so a road test was was reading the other day stated. Very very slightly different gear ratios, so nothing really.
However if you want to up the power to 110, dont bother fitting the 110 things, just get it remapped. It should easily see 110bhp and more, may increase MPG too. Depends on the map type and how you drive it.
Remap would be my option, they do well with a remap.
Chris.
Chris.
19 Hyundai i10
19 Hyundai i10
CitroenMad,
Gearbox's are different, 110's are MLt5, and 90's are the older BE cable clutch..
Final drive I think is slightly different but I cant remember now when mum had her 90 what it was like..
Flywheels between the boxes are different too, I had to swap that over... input shaft on the ML gearbox IS bigger then the BE box I also found when my alignment tool was too small
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Nothing particularly clever about the ecu controlled valve. Most turbo equipped cars from the modern era have ecu contolled pneumatic valves.Stunned Monkey wrote:Variable vane turbos weren't about when the HDi was developed. it's definitely not a VVT. Boost control is achieved with a very clever vac-actuated (ECU controlled) wastegate.
On petrol engines the air source is typically from the turbo compressor housing. Citroen on the HDI use a vacuum source from the engine driven vac pump.
Now using '00 Xantia LX HDI, pov spec
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident
'99 Xantia HDI 110 Exclusive, RIP
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped )
& a couple of Peugeots !
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
Variable nozzle is just another term for variable vane. The generic term for this type of turbo is variable geometry. Interestingly VGT's more often than not don't have a wastegate , boost control being achieved by the varaible vanes.Kowalski wrote: You're right that neither the HDI 90 nor HDI 110 have variable vane turbos, the later HDI 136 (both 2.0 and 2.2) have variable nozzle turbos which accomplish the same job in a slightly different way.
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
- Kowalski
Citroen has a technology that is different to the standard variable vane turbo, I was referring to it has variable nozzle, but it would appear that both terms are used interchangeably.....HDI wrote:Variable nozzle is just another term for variable vane. The generic term for this type of turbo is variable geometry.
A variable vane turbo has a set of vanes around the outside of the turbine which move.
http://media.photobucket.com/image/vari ... levane.gif
The alternative is a nozzle over the turbine which slides along the same axis as the turbo's shaft.
http://jacky.wallet.free.fr/Jacky/Autom ... itroen.jpg
http://jacky.wallet.free.fr/Jacky/Autom ... le_tgv.htm
The site I've linked to is in french, so the correct name for the technology would have to be translated.....
Cool ! So variable vane with a difference ! If this is unique to Citroen it would explain why I've never seen it. Do they manufacture it or is it produced for them by one of the Turbo manufacturers ?
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
Well actually, yes and no... There is a Vaccum pump on the end of the Cam shaft, BUT however, this is connected FIRSTLY to two Electro Valves, and these ARE ECU controlled, so it knows when to OPEN the waste gate for the Optimum Set Boost PSI set in the ecu, and the other open the EGR valve by vaccum.. hence why your getting boost problem (I THINK) because one of the Electro valves is not working... either stuck open not allowing enough boost hence holding the Wastegate open, or holding the wastegate closed allowing ALL boost into the engine and triggering the ver boost valve.. Theres a Boost sensor so the ECU knows how much its getting on top of the Intercooler, passenger side..HDI wrote:Nothing particularly clever about the ecu controlled valve. Most turbo equipped cars from the modern era have ecu contolled pneumatic valves.Stunned Monkey wrote:Variable vane turbos weren't about when the HDi was developed. it's definitely not a VVT. Boost control is achieved with a very clever vac-actuated (ECU controlled) wastegate.
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- Kowalski
I know that the 2.2 HDI certainly got that type of turbo, so any car with the PSA 136BHP 2.2 HDI engine in it will get that type of turbo e.g. Peugeot 406.HDI wrote:Cool ! So variable vane with a difference ! If this is unique to Citroen it would explain why I've never seen it. Do they manufacture it or is it produced for them by one of the Turbo manufacturers ?
http://img.alibaba.com/photo/105968797/ ... T1549P.jpg
According to the web, that turbo is a Garrett GT1549P.
The 2.0 HDI 136 gets a different turbo with a more conventional variable vane setup in the form of the Garrett GT1749V, which is also used on a number of other diesel engines, e.g. BMW 2.0, VW 1.9,
