Thanks Lexi. Well, the old hose is still in position. If I had had more time...
The blower is working beautifully now, and I've been driving around for two weeks since passing the MOT. Unfortunately, my local exchange knocked out my asdl broadband for over a week and couldn't post or read.
The car is driving well now that....
I sorted out the brakes and hydraulics, which entailed new discs and pads, new spheres all round, and a fix to the diver side abs ring, the diagnosing and fixing is detailed in this topic
http://www.frenchcarforum.co.uk/forum/v ... hp?t=28573. The symptoms had involved pulling to the left and both small (nitrogen) and large (air) bubbles in the hydraulics, along with pulsating through the brake pedal when braking, as well as abs coming on all the time. I am really grateful to all who contributed to that, and so helped me.
I also took a look at the alternator belt, which squealed a lot, and found it to be slack with a shorter (than specified) belt fitted, and the automatic tensioner faulty. The tensioner needs to be replaced shortly, though I have tightened the belt with the eccentric tensioner, and it's quietened down. I got good help here in this topic :
http://www.frenchcarforum.co.uk/forum/v ... hp?t=28670
New wipers were a joy to use in warm cabin. The car is watertight, and I drove through a couple of deep - about 2' - tunnel floods, with height set to max.
Managed to get some genuine roof bars, and found they didn't fit - too wide. Disappointed I drove half the load to the other side of London, and then discovered that the front bar is wider than the rear bar: they do fit afterall!
I have a nice car set up to run with loads of renewables fitted.
The process of filling some scratches by building up with acrylic paint and rubbing down is well on it's way. Then it'll be ready for a final cut and polish.
The rubber fuel priming bulb is badly cracked and developed an air leak with my testing. I temporarily bound it with tape, and that fixed it OK for the time being, as it wouldn't start. I felt like just removing it. I guess I can
It's been intensive and hard at times. I am on top of it now, it's been worth it. It would have been much easier if I had been able to do so much work indoors indoors, and if I had known xantias before I had begun! It's great to be sure. The questions drove me a little crazy, not as much as the ordering did, and the constant re-setting up a work space, and sorting the tools. Having taken a much needed rest from all that, I feel quite lazy about the car now. My children like the car. I had one booster seat, and used a cushion for second, I should hope that's legal , and as good a solution.
I have two jobs upcoming
Replace a driveshaft outer sphere and alternator belt tensioner. Also, replace the gearbox oil on a lexia machine. It's running on hydraflush right now, so that'll be to replace in about 1000 miles. Feels slightly twitchier with that blood. I noticed the car sunk overnight at the back when filled with a heavy load. The flush is doing it's work at the moment. I may have to turn y attention to the anti-sink valve in the future. I guess I'll also turn my attention to the engine mountings and cam belt, when those are completed.
I imagine all the things to do will be delayed by winter and moving to the North of England. Anyway, The parts are arriving, and I like it one thing at a time, again!
