1.9TD Xantia engine running issues
- My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising - x 71
Thankyou crossy2425,
you took the words out my mouth, or off my keyboard!
Obviously the Perkins has a wider tolerance for allowing the valve to piston timing to be out... but generally DERV timings should be damm near spot on...
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- Paul-R
- Donor 2023
- Lexia Available: Yes
- My Cars: 2015 1.6 Blue HDi 120 Peugeot 308 Active SW
2013 2.0 HDi 163 C5 Exclusive Tourer
2003 2.0 HDi 110 C5 Exclusive Estate (Gone)
2001 2.0 HDi 90 Xsara Estate (Gone) - x 1381
I KNOW it's not the same engine - the point was that the engine ran with the pump being timed wrongly. The cam was timed in correctly to the crank so there (fortunately) wasn't any "test" of piston to valve clearance.
BTW it was only the Prima when sold by Perkins, in the Montego and Maestro it was officially the MDi engine.
I discovered some years ago that a CX diesel will run (albeit badly) with the pump timing 180 degrees out!
Really confused me for a bit; I thought the replacement pump was duff until I had a cup of tea and a think...
Jonathan
1986 Mercedes Benz 190D 2.5
1979 GS 1220 Club Estate awaiting more welding
1952 David Brown 30D awaiting new liners
- Old-Guy
- My Cars: 2011 Grand C4 Picasso VTR+ 1.6HDi in Kyanos Blue
1995 Xantia Estate SX 1.9TD in Vert Vega "The Green Lady" - now owned by XanTom
1998 Xantia 2.1 VXD Estate in Mauritius Blue - R.I.P. (terminal tin-worm) - x 17
Bob, once you've changed the engine mounts, and got rid of the horrible vibration at hot idle, you'll be wanting to sort out the lack power?
I suggest the FIRST thing you do is to check that the boost pressure sense pipe that run from the O/S plastic air pipe to the top of the injector pipe. If this is split (the give-away is oil over the top of the cam box),
the pump will 'think' there's no turbo pressure and will limit the fuel supply accordingly. In fact, the loss of boost pressure will be quite small (small pipe on even smaller spigot) but the injector pump won't sense much or any boost pressure. It's a five minute job to check the pipe and not much longer to replace it. It happened on my slightly older 1.9TD (95MY built 01/96) - the performance was transformed.
It now blasts up Haldon Hill (on the A38off the southern end of the M5) fully laden in 5th at the legal limit and sees off the 2.0i also in the family.
Guy
Guy
1995 Xantia Estate SX 1.9TD in Vert Vega "The Green Lady" - after 11 years now owned by XanTom
- Contact:
