Guess the part that fell off!
MikeT
My Cars: 2005 C5restyle 1.6HDI 16v 110hp VTR Estate
2008 C5 X7 1.6HDI VTR+ Saloon
x 232
Post by MikeT »
If you'd like me to give a second opinion, text me when you're available and I'll pop over. I'm not able to do much today so will just be moping around. That's not to say that I can unravel the mystery, of course.
Mosser
My Cars:
Post by Mosser »
Did you fix this problem ?, i had long bits of thin metal coming out the BACK of my crank damper pulley for the last few days accompanied with a nasty rattling sound from the belt area, so i took off the damper pulley to find it was disintegrating and thin slithers of metal coming out the back (not the front) of the pulley.
So even if your damper pulley looks fine, get it off and check the back, you will probably find its knackered and in need of replacement
2002 Peugeot 806 quicksilver HDI with bosch ecu
Toby_HDi
My Cars:
x 3
Post by Toby_HDi »
Nope, never did work out what it was. Some say it was the crank pulley but when I took it off it all seemed fine.
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
oscarloco
My Cars:
Post by oscarloco »
Toby_HDi wrote:Nope, never did work out what it was. Some say it was the crank pulley but when I took it off it all seemed fine.
In my case when the lower pulley damper failed, the engine made a high pitched sound and the charge light came on as only the inner part of the pulley was turning. The only warning I got was a couple of days earlier in the mornings during startup that the engine sounded like there was a loose belt.
Anyway, if the debris are metal, it could be the metal seal of a bearing. How big are the debris?
Oscar Lopez
'94 ZX 2.0 8v petrol (restoration to its former glory on its way after being neglected by stupid Ex)
Toby_HDi
My Cars:
x 3
Post by Toby_HDi »
Nope I never had any of that. First I knew of it was a sort of grinding noise and the smell of burning.
After I retrieved the debris the car sounded very rattly, all seemed fine though. They were about 6 inches long maybe a bit more
Toby
Previous:
Post Reply
