Steering knock/creak
- My Cars: 2005 C5restyle 1.6HDI 16v 110hp VTR Estate
2008 C5 X7 1.6HDI VTR+ Saloon - x 232
If it's any help diagnosing this; Toby invited me to try it while the engine was running, I felt a sort of slight resistance, a gritty, pulsing feeling through the steering wheel at a very acute point when turning the steering back from left lock, just before the wheels came dead ahead. I couldn't hear anything from the top of the engine.
- My Cars: Currently:
In the past: 3, CX td Safaris and about 7, XM td estates. Lovely cars. - x 1207
Ah, thanks Mike. Pulsing is normally a sign that the pump/accumulator is not supplying enough fluid, but the fact that its only doing it in one spot could mean the the ram is allowing fluid past at that point.
Toby
I am at the other end of Dorset, Devon border, but if you fancy bringing it down I will have a look.
Toby
Thanks for the offer Peter, I may take you up on that, pm to follow shortly
Just an update, its now occuring around the same position when turning the wheel left though not nearly as bad as when turned to the right. Doesn't sound too healthy anyway
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
Previous:
Hi Toby
I had the same thing with my rack on the xm, along with clunking if ii vigerously wiggled the steering, i put a new rack in and all is now well but the creaking was very old hard and spliting handbrake cables rubbing in the guides 8) , would mainly do it turning right because that was the longer cable with more guides to creak in as it was pushed in by the movement of the wheels.
Dont think a rack could be dry enough to creak, alternativly it could be the uj at the bottom of the column just above the pinion getting dry joints
Hope its cheap
D
Hope its cheap
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
my experience
when i swapped an engine,
they ran the engine, but suddenly my steering wheel is heavy
so, what they did is to put some sealant above round cylinder above
lhm reservior / filter housing / above it
but i still have it now, because permanent remedy is to change it - the filter housing. what do you think?[/quote]
