My "love" of all things xantia...and Xm...and Cx..
davetherave
x 4
Unread post by davetherave »
S2, Lol thing is i promised i wouldnt buy any more cars!
Ill have to see if i can spare a bit of time stripping the worst prestige down to get rid of it!
Good idea with the front end Jim, but i doint fancy re spraying it everytime i swap cars!
(95) XM Silver 2.1td Exclusive.
(87) Cx 2.5 DTR T1 undergoing major cosmetic surgery.
GPZ500s
Citroenmad
x 110
Unread post by Citroenmad »
S2 V6 12vs are reasonable rare arnt they? What reg is it on? I assume its not silver then!
I can imagine it might be quite hard finding a front end.
Are you happy with your 2.1TD now then? Or is it still an ongoing thing? Mind it always is with cars isnt it.
07 Citroen C5 HDi VTR - Red
09 Citroen C3 1.4i VTR - Silver
01 Citroen Saxo 1.1i Forte - Mango Orange
93 Ford Mondeo 2.0i GLX
19 Hyundai i10
davetherave
x 4
Ive contacted the guy and said i would like it! Not sure how rare they are. As for the front end hopefully ebay will come up trumps, i dont mind painting it anyway.
The 2.1td is always an ongoing project!
If the V6 were able to go back on the road then it would have to be a seldom used car!
GPZ500s
Deanxm
x 87
Unread post by Deanxm »
Dave, guess what ive got here...................a complete MK2 front end, all as one piece with the fans on it and everything, even headlamps and nose cone, here it is.....
It was taken off the car as you see and put in the store room, im not a MK2 fan so if you want to collect you could have it for free, one catch though......im on the isle of wight, is there a FCF courier going this way? :lol:
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
x 6684
Wow, result! Well done Dean!
An offer too good to resist there Dave :D
Now, will an XM front end fit inside another XM for transportation purposes?
davetherave
x 4
Dean thats awesome, will have to look into transporting it. probably wont have any time untill september but ferries dont seem too expensive!
The guy cant remember if he officially scrapped it or not, so wilh ave to find out before i say for definate! Also need to source a front wing, but cant remember which one!
Cheers
Dave
GPZ500s
Deanxm
x 87
As you can see an estate will take it easy, mind you id say you could get a Xantia in there though :lol: , we might be able to do a deal on a wing too, i think i have 4 in Manderin red but they would be for beer tokens because they are a 'maybe usefull' item.
D
XM Prestige PRV6 92
Toby_HDi
x 3
Unread post by Toby_HDi »
If it helps, if they can be shipped over the Solent. I can pick them up and take them part way up.
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
davetherave
x 4
Sounds good dean, will have to contact you when i find out for definate if its a fixer upper or breaker!
Im thinking i could do a couple of days trip to the isle of white with a mate and incorporate the picup then!
Thanks for the offer toby!
Should be getting it at the end of may, but ill keep you updated!
GPZ500s
Deanxm
x 87
No worries, just let me know what you want to do, that V6 will be a keeper, any V6 is worth saving!!!!!
D
XM Prestige PRV6 92
Citroenmad
x 110
Yes, looks to me that the front would go into an XM hatch too, the estate is a little longer but looks like there is room to spare. Estates are huge, ive had both of the 6hs bonnets in ours, with room to spare too.
Hope you get the V6 Dave, would be hard not to with the offer of the front end.
19 Hyundai i10
davetherave
x 4
LEXIA UPDATE
I now have a working lexia!!!!! :D :D :D :D
Runnning on vista...... :twisted:
Well actually thats a lie, its running off of Xp inside of vista!
I can now communicate with the car, however this is slightly depressing as there is more wrong than i though!! :(
Here is a screen shot of my conversation with the suspension ecu
No idea what im going to do about the permanent rear electrovavle fault :? , but i have erased all the others!
I also talked to the ABS ECU and found that it reckons its getting inconsistant data from 3 of my sensors :o , thats not going to be cheap at all!
However ive erased the faults and will see which ones come back!
GPZ500s
x 6684
Well done Dave, on getting the Lexia working..
I see you have the normal crop of hydractive faults :)
Electrovalves that come up with permanant faults normally need to have the diode mod carried out and then tey'll be OK. Otherwise there is a wiring fault.
Explains the hard-riding rear too...
Looks like you've found the cause of the "funny" brakes too if the Lexia is finding ABS issues. It all ties up...
Prepare to shell out on ABS sensors...
davetherave
x 4
Thing is i did the diode mod! I soldered two diodes internally into the ECU! :?
GPZ500s
x 6684
davetherave wrote:Thing is i did the diode mod! I soldered two diodes internally into the ECU! :?
That should have been OK then Dave :?
Can you hear the rear valve purring at all? Is it generally behaving as it should?
Under such circumstances, I'd temporarily substitute another electrovalve just for test purposes. No need to fit it, just hang it off the wiring...
Have you checked the plug on the electrovalve. It might be a bad connection in there due to a bit of corrosion.
If the symptoms persist with a substitute test electrovalve and the wiring is OK, it must be something unhappy with the VN05N driver IC...
If you can get hold of a 'scope, have a look at the waveform at the valve...
It should look like this:
Does your Lexia have an oscilloscope function?
