front end whine..?
marco1
front end whine..?
hi on going ..changed both front wheel bearings,drive shaft support bearing,still got wineing going round corner,typical wheel bearing noise..but all been changed!!!could it be in the diff,gearbox as sweet as a nut been like it 8 months now, strange got no worse than when it first started.and what in diff would make such a noise.car a dream apart from that..any idears..
jeremy
Yes the differential could make a noise when cornering as its only active when the front wheels are moving at different speeds, but i would have expected there to be a significant difference when the car was accelerating, decelerating or just running steadily. If you have a smaller spare wheel you could try fitting it and seeing if there is any difference. If it is the differential I would expect it to now be noisy in a straight line.
Jeremy
Jeremy
