Deanxm wrote:Being a C1 driver i cant see you have never changed a clutch before now Chris, some C1's actualy make it home from the dealer before needing a new clutch
The activa was doing the same though, on the way home from the cxm last year it was pretty bad and a steady run at 70mph was called for, in fact after leaving i went to get petrol and there was a bad hill with a roundabout at the top and that had to be taken very gently
when i got home it was aweful, just nursed it about when needed, now its perfectly driveable and will alow full throttle but maybe tomorrow it wont, its very fickle, the bite point is high though so the clutch is shot but there is no oil in there i know that.
D
Your quite right, C1s have a poor record with clutches. However its always put down to wear and tear as the friction plate is usually just worn thin and so is put down to driving habits. Many people ride the clutch when at junctions, keeping the car still on the bite and this wears it out. As a city car they must get a lot of stick in this way, also its easy to overrev the C1s if your not used to them and so slip the clutch when pulling away. Its mainly down to driving as that is the only way to wear out a friction plate, many C1s have done many more than the average mileage on a clutch, I know of a few with over 100K and still on the original.
However, all facelift C1s, like ours, have a bigger clutch from the Yaris and are much hardier. So perhaps the clutch in original C1s was a bit weak for the job.
My C5s clutch only slips at 2000rpm if ive floored it at 2000rpm, it then revs about 5-600rpm higher and then the speed catches up with the revs. I did 80 miles in it yesterday, driving quickly but avoiding full throttle at 2000rpm, it only slipped once - when I tried it at 2000rpm as it seemed fine.
I took my C5 into the garage today who is doing the repair, ive not heard how far they have got with it but ill ring tomorrow and find out how its going. Hopefully it will be finished on saturday but it depends if any more bits are needed when they strip it down.
