All was perfect until it broke down the other day! On my first inspection, I thought it may have been the head gasket - the engine still runs but runs on what seems like 2 or 3 cylinders. A lot of shaking around as it runs (I guess due to the uneven ignition).
There has been no temperature increase/boiling and I can't detect any oil in the coolant. The dipstick and oil filler look ok and no obvious bubbles of coolant in the oil.
I have noticed quite a bit of oil inside the air flow pipe at the top of the engine (the fairly straight plastic one that connects to the short piece of hose near the top on the manifold) when i removed it the oil was resting in the bottom of the short pipe.
I am starting to think is that the there maybe some sort if injection problem. There is diesel getting to the injectors but I am wondering if the recent work might have finished off an injector or two?
Any Ideas? cheers
