Xantia coolant leak after cambelt change
As Xac said, a jack with a block of wood under the sumpworked fine for me. You don't actually need much movement to get to all the bolts.
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
Previous:
- XantiaExclusiveHDI
- My Cars: Xantia HDI 110 Exclusive Saloon - I can't seem to let her go!
OK - I've read up further. I think it's way beyond my capabilitiesToby_HDi wrote:As Xac said, a jack with a block of wood under the sumpworked fine for me. You don't actually need much movement to get to all the bolts.
Haynes reads that you also have to remove the rear engine mount - which requires removing the driveshaft - which requires a special tool and draining the transmission and on and on it goes...! I had no idea this was such a complex and lengthy procedure - just to get to the water pump!
I'm so frustrated now. Given the garage left half the bolts undone on the covers and the right hand engine mount - I dread to think what else hasn't been done correctly looking at this procedure.
I'm going to declare my car SORN and use my bicycle which I've been using since this mess started. I've lost all trust in garages now thanks to those idiots.
Oh well...
Currently:
2000 Xantia HDI 110 Exclusive Saloon (73k)
Previously:
BX 19 TZD Turbo
Previously:
BX 19 TZD Turbo
- Xaccers
- x 184
Remove the rear engine mount???
Are you sure?
Shirley it's just the driver's side engine mount at the top...
Are you sure?
DIY sphere tool
DIY sphere tool
- DickieG
- Monaco's youngest playboy
- x 38
Err no you don't, or at least I didn't when I changed the belt on my HDi yesterday.XantiaExclusiveHDI wrote:Haynes reads that you also have to remove the rear engine mount - which requires removing the driveshaft - which requires a special tool and draining the transmission and on and on it goes...! I had no idea this was such a complex and lengthy procedure - just to get to the water pump!
13 Ram 1500 Hemi
14 BMW 535D Tourer
19 BMW i3s
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
14 BMW 535D Tourer
19 BMW i3s
06 C3 Desire 1.4
Pah! That's Haynes for you then! It reads in the 2.0 Litre HDI Chapter 2C.5 - Section 6: Timing Belt Covers removal and refitting step 16: 'Remove the right hand engine mounting and rear engine mounting as described in section 17'DickieG wrote:Err no you don't, or at least I didn't when I changed the belt on my HDi yesterday.XantiaExclusiveHDI wrote:Haynes reads that you also have to remove the rear engine mount - which requires removing the driveshaft - which requires a special tool and draining the transmission and on and on it goes...! I had no idea this was such a complex and lengthy procedure - just to get to the water pump!
Section 17 goes on to say that in order to remove the rear mounting the right hand drive shaft has to be removed as in Chapter 8.
I'd rather trust what you guys suggest
OK - I'm feeling a bit better about it if that's the case! Just ordered a nice shiny new metal impellor pump. Oh and ordered the Sisters car out of the garage for an unforseen amount of time
Currently:
Previously:
BX 19 TZD Turbo
Previously:
BX 19 TZD Turbo
Indeed, as DickieG says, you do not need to remove the rear mount.
There is a reason the Haynes is know as the Book of Lies (BoL) around these parts
By doing it yourself you will save a nice sum of money and once completed have an immense feeling of satisfaction and pride that you done the job yourself.
Of course, there will also be help and support from the chaps on here every step of the way
Toby
Previous:
Previous:
- DickieG
- x 38
Good point here Toby because as soon as I removed that bolt coolant leaked out of it, at first I thought I'd split a hose somewhereToby_HDi wrote:One other thing to note is that there is a cambelt cover bolt that also retains the coolant pump. You mention loose bolts so this could be worth looking at. IIRC from when I did mine it is an 11mm headed bolt
13 Ram 1500 Hemi
14 BMW 535D Tourer
19 BMW i3s
06 C3 Desire 1.4
14 BMW 535D Tourer
19 BMW i3s
06 C3 Desire 1.4
Thus Far...
Today was THE day....
I am pleased to report it has all gone quite smoothly thus far (I really shouldn't be tempting fate by saying that should I....)!
Where do I start?!
Removing the top cover was easy enough. I supported the engine from below with a trolley jack topped with plywood and by the side of that I built up a further support of concrete blocks topped with plywood - just in case. The intermediate cover was more difficult - but I found I could reach the bolts and remove them without lifting / lowering the engine as suggested in the BoL! I used a ratchet spanner and a degree of patience... Maybe I've got nimble fingers
Locking the auxilliary drive belt was tedious but manageable. I used an allen key taped to a screwdriver to give reach which worked very well as the locking tool!
The crank pulley was interesting... I found the best way was with a 2 foot breaker bar and levering up from the underside in front of the car. A few hard pulls up and it slackened off. Lower timing cover was easy after that.
I had to dismount the starter (not before removing the air cleaner box which gives better access to the bolts) to get access to the flywheel locking hole. My method of locking the fly was to use an 8mm drill bit taped to a screwdriver at right angles - which was then levered with the aid of an elastic band tied to a suitable point. Then as I turned the crank slowly around the point of the cam sprocket alignment position - the bit popped in at its alignment position. Yippee!
I decided to just remove the timing belt from the water pump and the tensioner as it was only the pump I was interested in.
As I thought - three of the timing cover bolts were loose - and one was indeed securing the water pump. This was where the water had been leaking from. I took some photo's!
I removed the pump and replaced it with the new one complete with new gasket - after cleaning up all the surfaces and applying a little hematite.
I replaced the timing belt - tensioned up - removed the locks and rotated the crank ten times. I then managed to refit the two locks successfully.
Currently I have the belt tensioned so that I can just turn the top run 90 degrees with the same force as before I relased the tensioner.
That's it for today!
All is well - though I KNOW I shouldn't speak too soon!
All in all - I have to say if I complete this job successfully I'm going to be mighty proud
I'll also be mighty grateful to all you guys for your advice
I will also be wondering why I paid so much for the job to be done so badly!
Will report back on tomorrows proceedings...
C.
Where do I start?!
C.
Currently:
Previously:
BX 19 TZD Turbo
Previously:
BX 19 TZD Turbo
Hi Xantexc
Its a good feeling when a plan comes together isnt it 8)
The sad truth is even when a garage has given you no cause for concern after work has been completed, 9 times out of 10 if you get under the car and have a look yourself there is something that isnt done right .
D
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
Job Done!
Today I started by draining what was left in the cooling system then flushing everything out. I filled up with new coolant / de-ionised water utilising a header made from a 1 litre de-ionised water bottle. I used adhesive backed foam strip for sealing the neck. There were two bleeding points that I could find - one on the thermo housing - and one on a heater hose at the bulkhead. I filled up until these flowed with coolant. I removed the two locking tools then reinstated all that had been disturbed aside from the intermediate and upper timing belt covers.
Then I checked everything over and over to make sure I hadn't missed anything.
I sat in the drivers seat and said a little prayer to the Citroen God
I turned the key and hey presto!
I ran the engine for 30 minutes or so with the cabin heater on hot and kept squashing the upper radiator hose to help dispurse any air. This eventually found its way up and out of the expansion tank via the homemade header.
After I was satisfied all air had been dispelled I decided to taker her for a spin. I took my mobile phone as well....
All was well. It was lovely to be back driving my beautiful Hydropneumatic Hover Car!
I drove for around 8 miles to get her up to temperature. On my return I checked everything including the timing belt tension. It had indeed tightened up - but I was still able to twist it 90 degrees but with quite some force compared to before. Is this about right would you say?
I didn't alter the tensioner on the auxiliary belt. This seemed to be OK and as before I could twist the longest run 90 degrees with a bit of force.
I now have a leak free car with a new water pump - renewed coolant and ALL bolts tightened up
Is there anything else I should be aware of or do following this job?
C.
C.
Currently:
Previously:
BX 19 TZD Turbo
Previously:
BX 19 TZD Turbo
