Cooling fans not working
Clogzz
My Cars:
x 36
Contact:
Post by Clogzz »
the missing feed
With the owner’s book saying ‘cooling fan’ fuse of 5A under the bonnet, you can be sure that’s the one feeding the coil of 1502.
There are some old topics about replacing that fuse to bring back the low speed.
The fans and their power wiring are good if when jumpering the relay sockets both fans always go to low speed from full stop.
around $700 ex-dealer
Supercheap sells bootleg fans for about $A90.
They need a different plug, and maybe tacking in with cable ties.
wondered about ... the Bitron
The Bitron output grounds the low ends of the relay coils, so cannot have a signal waveform on it.
The diagnostic pin will have 12V coming through the relay coil at rest, and 0V when energised by grounding through the Bitron.
2002 C5 2.0i AL4 230,000 km 76372389
MikeT
My Cars: 2005 C5restyle 1.6HDI 16v 110hp VTR Estate
2008 C5 X7 1.6HDI VTR+ Saloon
x 231
Post by MikeT »
Took some time but I've managed to make a little headway with this problem. Wasn't easy with pack of printouts, haynes manual and citroen handbook in a dusty wind :twisted: but here's the result so far.
To recap, we discovered a missing +12v from Pin 1 of relay 1502 (Left Fan Relay). There may be more faults in the circuit but what I've checked so far is good (and I haven't been able to to work out if this open circuit will cause the very symptoms I've described :oops: ).
I have ascertained this open circuit fault to lie somewhere between fuse F14 and Pin1 of 1502. However, according to the diagrams, between these two components the wire also feeds Pin4 of the Bitron unit and I can't determine what or where that junction might be, anyone know? (I don't even know where the Bitron is or even what it looks like. I noticed what looks like a Relay marked, "Bitron" in the engine bay fuse box).
From what I can gather, the loom runs from the passenger fuse box, out along the O/S wing, under the radiator, up into the battery area then back across to the fans - am I correct?
DickieG
Monaco's youngest playboy
My Cars:
x 38
Post by DickieG »
MikeT wrote:(I don't even know where the Bitron is or even what it looks like. I noticed what looks like a Relay marked, "Bitron" in the engine bay fuse box).
The Bitron control box is located right under the N/S headlight, to gain access you have to remove the front bumper and IIRC the front panel behind it as its covered by the lip of the panel, great position,,,,,,,not!
You may be able to get to the connector plug without removing the bumper but its a right pig, you certainly won't be able to remove the unit as one of the securing nuts is covered by the panel mentioned above.
13 Ram 1500 Hemi
14 BMW 535D Tourer
19 BMW i3s
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
MikeT
x 231
Post by MikeT »
DickieG wrote:You may be able to get to the connector plug without removing the bumper but its a right pig, you certainly won't be able to remove the unit as one of the securing nuts is covered by the panel mentioned above.
Yep, that's exactly what was done Bumper off, then the plastic crash protector part behind it - only to discover the fault isn't with the Bitron or it's connectors. I'll put the full details in my blog but can declare we've found the problem and Citrojim lost his bet. :lol:
My Cars: Bluebell the AX, Polly the C3 Picasso, Pix the Nissan Pixo, Propel the duathlon bike, TCR Pro the road bike and Fuji the TT bike...
x 6204
Contact:
Post by CitroJim »
MikeT wrote:I'll put the full details in my blog but can declare we've found the problem and Citrojim lost his bet. :lol:
Always happy to loose a bet Mike, I usually do :lol: :roll:
I'm waiting with keen anticipation to find out what it was!
bosrasham123
My Cars: c5 mk2
saxo 2000
Re: Cooling fans not working
Post by bosrasham123 »
hi could u tell me were the cooling fan switch is on a 2006 Citroen c5 2.0 hdi vtr
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow
x 5741
Post by GiveMeABreak »
bosrasham123 wrote:hi could u tell me were the cooling fan switch is on a 2006 Citroen c5 2.0 hdi vtr
You'll need to post up or send your VIN by Private Message as they are different depending on engine and model.
Post Reply
