Actually from what I've read you don't want to go over 50% anti-freeze, even in cold climates.Toby_HDi wrote:Yes, so far I have 5.5l Antifreeze and managed about 2l of waterAndersDK wrote:If you mean continue to top up with water - then yes.
You are completely safe even if you hit a 1:3 mix coolant:water.
Although the freezing point might go a bit lower, anti-freeze (without water) is apparently a poor heat conductor so the cooling ability of the coolant is considerably reduced if you go too far beyond 50% anti-freeze.
I've generally seen a minimum of 33% anti-freeze (glycol based) recommended for warm climates ranging to a maximum of 50% for cold climates.
Regards,
Simon
