chaps anyone have an idea about this quite pretty red dust in the driver's hub? the bearing feels dodgy to me, so will change it as well as the very noisy Near side..
tried today to get someone to press them, best I had was £30 per side.. almost feel like buying a press but I have managed so far without, and its something else in the way really..
The engine is now lying on the bench.. the oil on the cam side? I am sure (I hope) its just residual from the Intercooler spraying mist for months or years... if not, this gunge is headgasket really.. but the fact its up and down from the join makes that seem unlikely..
also, some cam carrier internal pics.. looks worse than it is! the cams lobes are all perfect mirrors which is encouraging.. I don't want to remove the head.. but really if anyone can add to a pro or con for its removal I would be grateful.
so far :
clutch (worked but should replace)
near side wheel bearing (very noisy)
offside wheel bearing feels odd and the red dust
offside shock
rear engine mounting
offside seized caliper (now free but don't think its saveable)
both driveshafts
the main lower crossmember
a turbo rebuild (new cartridge)
injector work
oil
gearbox oil
filters (oil, air, fuel)
driveshaft seals
and of course the elephant in room, the welding
hence doing more work, or more costs, just is a step too far (headgasket)
looking at the cam side pic again, maybe the rocker cover...maybe... just thought it was dry at the top there
