jgra1 blog
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
Could be snowy tonight and tomorrow :shock:
Jim I dont supose you have an exhaust flange bolt spare? the really annoying ones that hold frontpipe to manifiold?
I thought I had one but could not find it last night..
No idea what happened to the original (will be taking the exhaust system off to check its not gone inside :twisted: )
x 5230
jgra1 wrote:Could be snowy tonight and tomorrow :shock:
Snowed here this morning - there was quite a bit up Stanley way. Soon went though.
x 7218
myglaren wrote: Snowed here this morning
That won't stop me :D I'm planning to set off pretty early tomorrow morning for the journey up.
Have the kettle on for about 10'ish Steve :wink:
Will I get to see the Angel of the North Steve? Really intrigued to see it..
x 5230
10ish? Don't you know it is out of season now?
Yes, you pass within ¼ mile of the rusthea... Angel :)
If you want to go over the Tyne Bridge there is a layby you can stop in and walk around and admire it.
ETA - bring your brains with you as I need to pick them on a point or two (won't hurt a bit, trust me.) :)
x 7218
Excellent stuff. Must bring my camera 8) (and spare batteries :roll: )
myglaren wrote: ETA - bring your brains with you as I need to pick them on a point or two (won't hurt a bit, trust me.) :)
I'll put them by the car keys so I don't forget them...
x 5230
Sorry Jim, re-reading that it is a load of cobblers.
What I meant was that if you intend going over the Tyne Bridge, that that route takes you closer to The Angel and offers an opportunity to view it at close quarters, not that you can go and look at the bridge - which you could if you wished, but that is a separate subject.
jgra1
(Donor 2021)
x 36
7 hours drive, pretty much non stop , 350 miles and the tank still reads a fraction above half :D weather was all scaremongering, tonight ;)
Jim, take your time! take lots of photos from every angle...
I may wobble into the garage at 9 but wont be on all 4 cylinders until 11 :lol:
plan is
head on
belt on
compression check for good (or bad) measure
manifolds and fuel filter on
engine in
driveshafts, wires, cables, pipes on
champagne
or something like that, its late..
Dad has some relations over, and he seems a bit worse for wear !....
MikeT
x 233
Unread post by MikeT »
jgra1 wrote:Jim I dont supose you have an exhaust flange bolt spare? the really annoying ones that hold frontpipe to manifiold?
The exhaust fitting kit comes with a choice of two sets so I have a pair unused. They're slightly longer than the ones fitted on the 1,9TD. Would they do?
x 7218
Hi John,
Got home all safe and sound at 02.50 :lol: Great journey, the 2.1TD excelled itself and turned over 100,000 miles passing the Angel 8) I'll always remember that!
Fanstastic day, excellent. Enjoyed every minute :D
My Tom Tom started working as soon as it warmed up, poor thing was frozen :roll:
All the best with your endeavours tomorrow and a safe journey home 8)
Off to get a few hours sleep now. It's almost 24 hours since I have :lol:
reblack68
Unread post by reblack68 »
citrojim wrote:I fitted a Witter on my 1.9TD John and my box trailer sits very high on it, just like yours. Caravan is fine though. Same with the Witter on my Estate although the design is totally different. On normal suspension setting, the caravan sits absolutely dead level on both cars.
The standard for towbar height was changed at some time in the 1980s. Our 1983 caravan sits at a funny angle. It's made worse by the self levelling, a lesser car would at least sit down a bit with the caravan on.
It's illegal to use a drop plate on a post 1998 car, or at least it's illegal to use towing equipment that isn't type approved for the car but I think you'd have to be unlucky to come across a policeman who A) knows that and B) cares.
Richard
Care of a 1994 205 D.
jgra1
(Donor 2021)
x 36
hi all,
Jim many thanks from Dad and I, we worked flat out yesterday from 9, but by 3 there were still a few loose ends and i needed breakfast and to get on the road.. shame, I think another hour or two would have done it. At least I have my 'heavy plant' crane back for the V6 and the Zetec SE engine changes :twisted:
I managed without any warning to 'do' another fuel filter, at Grantham. One flick of the engine light and a couple of miles of bad running and that was that! very different from last time (200 miles before it stopped finallly)
Anyway, 20 seconds with a torx bit and threw another filter in and all was fine from then on. :D
Steve, KP very sorry as I wanted to catch up with you both :(
I am not tied to driving up there next time, so may get a cheap rail ticket before they go up in price.
some approximate figures :
full tank and motorways, half loaded, but travelling at 60-70mph
636 miles
Full tank and enthusiastic lane driving, car unloaded, for 2 weeks,
464 miles
Full tank and driving as fast as I dare, exact same journey as the first one
570 miles
Journey from here to dads and back, via the A1 - 700 miles almost exactly
back later (our company has been taken over, and today is the sad day we loose all internet useage :( - until I bring a laptop in :) )
John
MikeT
x 233
Bump :)
jgra1
(Donor 2021)
x 36
hello Mike :)
its ok, the original bolt turned up :oops:
I didn't post a followup to the visit to dads as have been short of time and also cant access FCF from work anymore :twisted:
will work on it :)
x 7218
John,
When are you planning to go back up to your Dad's?
I was thinking and remembered something, now the engine has a Bosch in place of the Lucas pump, the original Lucas connector won't fit to activate the stop solenoid. It'll be necessary to pick up an ignition-switched feed for the stop solenoid. It does not have to be a beefy supply as there is very little current involoved. The replacement Bosch came with a plug for the stop solenoid wiring but with very short wires on it. If you look at the remains of the loom on the other engine, you'll find a similar plug with much longer wires on it and this'll be the better one to use.
Depending on when, I may well be able to come up again. I'd like to as I'd love to be there when the car rolls out of the garage under its own steam again :D
jgra1
(Donor 2021)
x 36
Jim would be great if you could come back up so we can see it roll out :)
there is so little time at the moment :( I think I have had 2 weekends at home since August
I thought of getting a cheap train up there, you could hop on at peterborough or grantham? or I train too either of these and we could go up in your estate :) I just cant face that journey again from here by car...
but I am away 20/21 and most of xmas ...
and i have loads on at home with the V6 and other stuff.. what a nightmare..
have you any hols left to take this year? like a friday off... could go up Friday morning back Sat morning?
dunno really, he is silly for moving so far away :lol:
