I screwed up. Car through Ford
ralph
My Cars:
Post by ralph »
What happened next?
Did the driver lose more than a front nearside wheel trim?? :wink:
2000 Clio 1.2 8-valve
1993 Mercedes 190E
2007 Honda FRV diesel
1998 Xsara TD, 293K - gone but not forgotten.
205s, 405, ZXs all loved and crushed.
Spud
My Cars:
Post by Spud »
Well!
We didn't have time to hang around for the rescue, but a kindly Discovery driver ploughed through, sending the bow wave through the open windows just before we left... :shock:
The police and a recovery truck were waiting at the other side......
1996 Xantia 2.0CT Estate
1997 Toyota Hilux Surf 3.0TD
reblack68
My Cars:
Post by reblack68 »
When water is running across the road like that it's entirely possible that there is a Fiesta, or even Discovery, sized hole in the road.
Richard
Care of a 1994 205 D.
weety
My Cars:
Post by weety »
if its set up the same way as the xantia engine you need to keep an eye on the automatic auxilliary belt tensioner....its so low down it can get get wet if you start er aquatic driving which tends to shorten its life (i have done two like that over the years)
M reg xantia 1.9td 266000 miles expired
R reg xantia 1.9td 186000 miles veggy power expired
L reg renault clio 1.9D 91000 miles expired at 107000 miles
x reg clio 15d veggy power bottom of the car rotted through
06 c5 2.2 TD wowser so much power and comfort 160000 miles
My Cars:
x 92
Post by citronut »
Spud wrote:Here's a Ford in the ford...... :lol:
that wont do much for its rust waranty, they rust quicke enough without that salt (sort ) of help
regards malcolm
ACTIVE8
My Cars:
x 6
Post by ACTIVE8 »
I wonder what the audience on the far right of the picture were thinking?
This could have also been one of many they had seen go wading/diving in!
ACTIVA
dr.lovexxx
My Cars:
Ford!
Post by dr.lovexxx »
Hi, Not an expert on Peugeot 405 but if it has a cat. on it I would check that as well as the down pipes and the joint between them. I had a Renault laguna and went through a flood not even as deep as yours when it was about 5 years old. The cat. was very hot as I had just travelled about 40 miles and a similar noise started with me. I took it to my mate and he told me the cat. was gone and the joint to the front pipe wasn't to good either. Replaced the cat. and everthing was fine, noise and fumes gone. If the cat. is damaged in any way this could make the car run slightly lumpy at tick over right throught to no power when trying to pull away.
Hope this helps.
OwenP
My Cars:
Post by OwenP »
dr.lovexxx, my first thought was the cat. etc. but have had all that replaced (needed doing anyway).
I am now thinking that some insulation on the bulkhead has gone awol, as the car is running fine (well apart from a dead battery, b****y cold weather) it isn't burning oil or excessive fuel, nor is there a lack of power.
It is just noisy, more so inside than outside.
2001 406 Rapier 2.0 HDi 90 Estate - Sold Scrap after being viciously attacked by a falling tree
2001 Toyota MR2 1.8 VVTi - To be sold for spares/repair - dead gearbox :(
2014 Seat Ibiza Eastate 1.4 FR ACT (bought in an emergency, but a nice enough low mileage car)
Post Reply
