Ok as soon as I saw the words "chronically understeers" I know you have a problem. A properly shod Xantia is not a chronic understeerer by any stretch of the imagination.addo wrote:This question might be one for you blokes, as there are that many more wagons floating about in the UK. Regular 6 sphere Series II is the one in question...
I've dropped tyre pressures down to factory placard levels (33 front/30 rear unladen) on the OEM size 185/65/15 rubber. Previously had them pretty high (44/42) for economy and accuracy of feel.
What I've found, is that at the lower pressure there is more control/graduation to how much the front scrubs out and chronically understeers, but it's happening at comparatively low speeds. Does this represent what others have found on similar sizes/pressures of tyre? Rubber is Toyo Teo front, ancient Olympics on rear. The kind of speeds I'm talking about are around 15km/k into a hairpin, or 35km/h into a tight 90° corner.
Two things - one is that the standard model does NOT handle as well as a Hydractive 2, the difference is quite noticeable, we have both so I've driven both quite a bit. There is no doubt the Hydractive 2 handles better. (And rides better too) On really tight cornering the standard model wont compete as it will roll too much.
The other main thing though is the tyres - 185/65/15 is undershod if you are trying to get handling performance out of a Xantia, plus I have no idea what the characteristics of those tyres are but if they are scrubbing in the corners they don't sound very good.
To give a comparison my Xantia (Hydractive 2) came with 185/65/15 "Champiro" tyres on it, and they were the biggest load of c**p I've ever come across. Even with full tread on them they squealed and scrubbed around tight hairpins or hard cornering and understeered / ran out on tight corners quite badly.
After about 3000Km (of admittedly spirited driving) the shoulders were completely worn off the front tyres.
I went to 205/60/15 Michelin XM1 and its like driving a different car. No real understeer to speak of, very close to neutral balance when you push it hard, no squealing or scrubbing of the front tyres and LOADS of grip in tight corners especially in the Hydractive 2 "sport" mode.
When I was testing a gadget that can measure G-forces a month or so ago I measured what it could do in a tight hairpin (120 degree) corner at about 30Km/hr and it was measuring 0.93 G's, and thats without the tyres squealing, nothing wrong with that (and no understeer - perhaps a touch of oversteer or self rear steering if anything)
I got over 30,000Km of hard driving out of those front tyres too, I like to chuck it around corners, I've just put a new pair on now.
Also, I'm running them at the standard pressures of 33psi on the front and 30psi at the back - I experimented a lot with the pressures when I changed the size of tyre but ended up coming back to the standard pressures.
No I think it's mainly a function of tyres that are poor and/or too small for the handling you're expecting. Go up a couple of sizes to 205/60/15 and to a better grade of tyre and it will probably be like driving a different car.Is it mainly a function of wheelbase and suspension geometry, this way it forces you to slow so much for corners?
Explain why you would want to generate oversteer ?Can oversteer be safely generated in a non-Hydractive Xantia, and if anyone has managed, what were the tyres/pressures/techniques?
Again, "comparatively slippery front end" sounds like poor tyres to me, I wouldn't classify a Xantia that way at all.With the comparatively slippery front end, I'm reluctant to power hard out of a turn in case it ploughs straight ahead and just gives me a bag of chassis/torque reactions to digest.
The grip limits of the Xantia with good tyres are surprisingly high - like I say on mine I measured 0.93G's of lateral force in hairpin cornering, although a non hydractive model may not do as well.Yes, I know it's not a Skyline or Lotus Seven, but it is a fun car that invites spirited driving. Just that I am keen to hear some seasoned opinions on where the limits really are. No point pushing it to levels of stupidity (or embarrassment, if one is more fortunate).
Thanks, Adam.
(disclaimer - don't test G forces on public roads )
Regards,
Simon
