The offside headlamp on my wifes 2003 HDi Berlingo is making an odd buzzing noise. Its just like the sound of a relay going nuts, disconnecting the light from the loom stops the noise and putting the lights on full beam also stops the noise. I had a quick look around but it was getting dark and I didnt want to pull it all apart, the lights still work so I decided to leave it untill later in the week when I have more time.
Does anyone know if these lights have relays build into them, and if so can they be replaced, or am I going to have to fork out on a new unit.
The BOL doesnt give much information, and I couldnt see a relay the headlamp wiring diagram.
Cheers
Berlingo Headlamps
vince
- x 13
Do they have HID headlamps? I doubt it ,but some powerfull types of headlamps have a booster pack on each lamp (cant remember the real name for it) as the standard electrical feed from the lighting circuit just doesnt have enough power.
Kind of an ignition coil for a headlamp. Other than that sounds like a short?
- x 94
srx600
- x 94
srx600
