The FFRR was reversed into in early november and took till the end of the month to get sorted.
Long and short, i was behind an arctic at a set of lights that just went red and i knew it would be a long wait so put her into Park and Handbrake up.
about 5 seconds later the arctic's reverse lights go on!!!
Then it starts to move!!
At this point i was a good 1.5-2m away as i could still easily see the bottom of his wheels and so on. The gap gets smaller very quickly and when he gets to 2' or so away i put my life into the horn
On the face of it the bumper had been pushed back in and perforated and the front grille had been bent/cracked out of shape and just missed the bonnet!
It was harder to see under the dirt as it was actually on its way home for a wash
He admitted fault and its all been sorted now. I had an SSRR(Semi Skimmed Range Rover, AKA Sport) TDV8 HSE for a few days. Until on the 3rd day the maxi fuse blew leaving me and the nipper stranded in the cold outside school after dropping the eldest off, then after about th 5th day i noticed she was a bit smokey. Checked the oil and it was nearly all gone! Called out LR Assist and they poured in what they had and then went off to a garage to get some more but he agreed either a turbo had died or the big end shells were on their way out(she was a little rattly for a newer diesel!) But the next day i was due to hand her back i left a smokescreen so thick you couldn't see from 1 side of a dual carriageway to the other. That earned me a police escort the rest of the trip back to the rental place as i dont think they believed i was on my way there
That got me swapped into a D4 XS (common theme of slowly working down the ranks...) which also got avery dirty as i do like how they handle the local mud with their std fit tyres
Got the car back and got the rear upper tailgate and bonnet painted at the same time for a very cheap price as the upper tailgate was showing ususal rust signs and wouldn't be repaired under warranty
I have one glitch left to fix which is the lower tailgate release and then shes great
I often help the odd stranded car i see thats broken down in a place i know i wouldn't want to be left as its so easy to just through the webbing out of the boot and the shackles onto the tow bar and move anything, 1 was a well laden big transit, think they are call jumbos as it was bigger than a high top, and low range certainly helped.
The D3's still tempts me as i know for what mine is a straight swap would likely be possible and it would be more economical but they do feel like such a large backward step or downgrade and the sounds system and noise inside the car
