That's a very sparkly, clean engine Larry
The microswitch is the glowplug post-heating defeat switch. The glowplugs continue to operate after the amber light goes off and the engine is started on a TD. They stay on if either the coolant is below 60 degrees c or the engine is idling. If you take the engine off idle (about one third throttle actually) the switch in question operates and cancels the post-heating by dropping out the post-heat relay.
The post-heat system also operates the cold start advance electrovalve on the side of the pump and having (usually) an orange wire attached.
In the UK, both post-heating and cold advance can be lived without fairly happily but is essential in cold climates. In Spain you'll be fine without it I would have thought unless where you are gets very cold in winter...
be very careful with second-hand pumps. You have the Bosch VP20 with automatic injection advance. Itr does not use an ECU to control timing. The VP20-AS3 looks nearly identical but has a three wire potentiometer in place of the microswitch and uses an ECU to control injection advance; they are not at all compatible with each other
Bosch pump seals
HI Jim
yes actually i had the head gasket changed in France on my way back from holiday.. fortunately it blew about 500 metres from my only mechanical friend.. hadnt seen him for 4 years, and had to say.. err could you fix my head gasket Anyway they skimmed the head too, so it should be squeeky clean and new.. didnt count on the pump going too!
so do you think my repair job will work? what's the chances of the pump going shkling quiplut! , or other noises on me when i start the motor?
cheers
Larry
cheers
Larry
(1996 Citroen Xantia 1.9TD LX with aircon)
Living in exile in Spain
Running on 100% veggie in summer
