Do you have a diving suit then?Xac wrote: With a bit of luck I can fit it tonight
Weather is a little moist at present...
New piece of kunifer replaced the rubber to pinion end, hopefully it will be flexible enough to get around the back.CitroJim wrote:Great newsHow was it repaired?
Play called off due to bad weatherCitroJim wrote:How's the pipe replacement going Xac?
Tomorrow looks like it'll be a better day XacXac wrote:Play called off due to bad weatherCitroJim wrote:How's the pipe replacement going Xac?
Will have to see what time I get back from Luton in the afternoonCitroJim wrote:Tomorrow looks like it'll be a better day XacXac wrote:Play called off due to bad weatherCitroJim wrote:How's the pipe replacement going Xac?![]()
If you want a bit of company whilst doing the job, let me know. I'll just be recovering from my efforts today. I'll bring my own chair![]()
I'm surprised you even notice Xac.. I thought your throttle pedal only had two positions - idling or flat to the floorXac wrote:The thinner gear cable makes for a lighter throttle pedal too
Exactly, it's shaved at least .2 of a second off my pedal to the metal timeCitroJim wrote:I'm surprised you even notice Xac.. I thought your throttle pedal only had two positions - idling or flat to the floorXac wrote:The thinner gear cable makes for a lighter throttle pedal too![]()
Still, I suppose the lighter it is the easier it is to bury it in the carpet
